Hi,
I want to capture images from a Basler acA1300-60gm and the ROS pylon_camera node. I can open and control the camera with Pylon's PylonViewerApp. But when I'm starting the ROS node with
roslaunch pylon_camera pylon_camera_node.launch
I get error messages that the frames can't be grabbed:
started roslaunch server http://192.168.1.2:45055/
SUMMARY
PARAMETERS
* /pylon_camera_node/binning_x: 2
* /pylon_camera_node/binning_y: 2
* /pylon_camera_node/camera_frame: pylon_camera_node
* /pylon_camera_node/camera_info_url:
* /pylon_camera_node/device_user_id: 1
* /pylon_camera_node/image_encoding: mono8
* /pylon_camera_node/inter_pkg_delay: 11772
* /rosdistro: kinetic
* /rosversion: 1.12.7
NODES
pylon_camera_node (pylon_camera/pylon_camera_node)
auto-starting new master
process[master]: started with pid [10507]
setting /run_id to ba1098f6-28e9-11e7-84cf-f44d30679130
process[rosout-1]: started with pid [10520]
started core service [/rosout]
process[pylon_camera_node-2]: started with pid [10529]
binning x is given and has value 2
binning y is given and has value 2
[ INFO] [1493036997.880801762]: Trying to open the following camera: 1
[ INFO] [1493036998.138585721]: Found the desired camera with DeviceUserID 1: acA1300-60gm
[ INFO] [1493036998.407568803]: Cam has binning range: x(hz) = [1 - 4], y(vt) = [1 - 4].
[ INFO] [1493036998.408075961]: Cam has exposure time range: [10 - 916000] measured in microseconds.
[ INFO] [1493036998.408277173]: Cam has gain range: [0 - 3] measured in device specific units.
[ INFO] [1493036998.411048207]: Cam has gammma range: [0 - 3.99998].
[ INFO] [1493036998.412463342]: Cam has pylon auto brightness range: [50 - 205] which is the average pixel intensity.
[ INFO] [1493036998.429420227]: Cam supports the following [GenAPI|ROS] image encodings: ['Mono8'|'mono8'] ['Mono12'|'NO_ROS_EQUIVALENT'] ['Mono12Packed'|'NO_ROS_EQUIVALENT'] ['YUV422Packed'|'NO_ROS_EQUIVALENT'] ['YUV422_YUYV_Packed'|'NO_ROS_EQUIVALENT']
[ERROR] [1493036998.676944253]: Error: 3774873620 The buffer was incompletely grabbed. This can be caused by performance problems of the network hardware used, i.e. network adapter, switch, or ethernet cable. To fix this, try increasing the camera's Inter-Packet Delay in the Transport Layer category to reduce the required bandwidth, and adjust the camera's Packet Size setting to the highest supported frame size.
[ INFO] [1493036998.729242950]: CameraInfoURL needed for rectification! ROS-Param: '/pylon_camera_node/camera_info_url' = '' is invalid!
[ WARN] [1493036998.729288645]: Will only provide distorted /image_raw images!
[ INFO] [1493036998.777814074]: Setting horizontal binning_x to 2
[ WARN] [1493036998.777900512]: The image width of the camera_info-msg will be adapted, so that the binning_x value in this msg remains 1
[ INFO] [1493036998.834390106]: Setting vertical binning_y to 2
[ WARN] [1493036998.834634538]: The image height of the camera_info-msg will be adapted, so that the binning_y value in this msg remains 1
[ INFO] [1493036998.839134313]: Startup settings: encoding = 'mono8', binning = [2, 2], exposure = 5000, gain = 0, gamma = 1, shutter mode = default_shutter_mode
[ INFO] [1493036998.840824354]: Start image grabbing if node connects to topic with a frame_rate of: 5 Hz
[ INFO] [1493036998.841150046]: Camera not calibrated
When I start the ROS image viewer roslaunch pylon_camera pylon_camera_node.launch
I dont't get images but more error messages from the pylon_camera_node:
[ WARN] [1493037429.575879168]: Pylon camera returned invalid image! Skipping
[ERROR] [1493037429.784726148]: Error: 3774873620 The buffer was incompletely grabbed. This can be caused by performance problems of the network hardware used, i.e. network adapter, switch, or ethernet cable. To fix this, try increasing the camera's Inter-Packet Delay in the Transport Layer category to reduce the required bandwidth, and adjust the camera's Packet Size setting to the highest supported frame size.
[ERROR] [1493037429.784979476]: Error: Grab was not successful
[ WARN] [1493037429.785294487]: Pylon camera returned invalid image! Skipping
[ERROR] [1493037430.034649674]: Error: 3774873620 The buffer was incompletely grabbed. This can be caused by performance problems of the network hardware used, i.e. network adapter, switch, or ethernet cable. To fix this, try increasing the camera's Inter-Packet Delay in the Transport Layer category to reduce the required bandwidth, and adjust the camera's Packet Size setting to the highest supported frame size.
[ERROR] [1493037430.034807885]: Error: Grab was not successful
I tried different settings for package delay, binning, framerate and PoE switch and inserter but it's alway the same problem. After i started and closed the roslauncher I can't open the camera with PylonViewerApp until I replugged the device. The app prints these error messages to console:
Failed to get the node 'AcquisitionFrameRate' from the device's nodemap
Error while reading properties
onUpdateNode : Exception occurred:
Node is not readable.
/home/builder/jenkins_root/workspace/PylonLinux_ReleaseBuild/linux-build-tools/build/lsb-gcc-x86_64-release/build/genicam/Genicam/library/CPP/include/GenApi/impl/EnumerationT.h : 131
Any idea what's the problem?
Originally posted by fehlfarbe on ROS Answers with karma: 108 on 2017-04-24
