Hi, I have a problem to use kinect2 in my ROS and look for lots of ways to configure that but still cannot. Firstly, I follow the instructions from:
https://github.com/OpenKinect/libfreenect2
This link is the kinect driver in linux. It seems that everything works fine except
*sudo dpkg -i debs/{libva,i965}deb; sudo apt-get install -f
it tells me that it doesn't contain libva and i965 directory, and fails.
I used another way to install them:
sudo apt-get install libva-dev libjpeg-dev
I skipped this step, and followed the instruction to the end:
./Protonect
And this gives me four images which includes depth image and RGB image. However, I noticed that, when I executed this command, the output in the screen shows:
jimmy@eaibot:~/libfreenect2/bin$ ./Protonect Version: 0.2.0
Environment variables: LOGFILE=<protonect.log>
Usage: ./Protonect [-gpu=] [gl | cl | clkde | cuda | cudakde | cpu] []
    [-noviewer] [-norgb | -no
depth] [-help] [-version]
    [-frames <number of frames to process>]
To pause and unpause: pkill -USR1 Protonect
[Info] [Freenect2Impl] enumerating devices...
[Info] [Freenect2Impl] 13 usb devices connected
[Info] [Freenect2Impl] found valid Kinect v2 @4:9 with serial 002305464947
[Info] [Freenec
t2Impl] found 1 devices
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 1
libva error: va_getDriverName() failed with operation failed,driver_name=i965
[Error] [VaapiRgbPacketProcessorImpl] vaInitialize(display, &major_ver, &minor_ver): operation failed
[Info] [Freenec
t2DeviceImpl] opening...
[Info] [Freenect2DeviceImpl] transfer pool sizes rgb: 2016384 ir: 608*33792
[Info] [Freenect2DeviceImpl] opened
[Info] [Freenect2DeviceImpl] starting...
[Debug] [Freenect2DeviceImpl] status 0x090000: 9729
[Debug] [Freenect2DeviceImpl] status 0x090000: 9731
[Info] [Freenect2DeviceImpl] submitting rgb transfers...
[Info] [Freenect2DeviceImpl] submitting depth transfers...
[Info] [Freenect2DeviceImpl] started
device serial: 002305464947
device fi
rmware: 4.0.3911.0
[Debug] [DepthPacketStreamParser] not all subsequences received 0
[Debug] [DepthPacketStreamParser] not all subsequences received 1008
[Debug] [DepthPacketStreamParser] skipping depth packet
[Info] [DepthPa
cketStreamParser] 2 packets were lost
[Info] [DepthPacketStreamParser] 1 packets were lost
^C[Info] [Freenect2DeviceImpl] stopping...
[Info] [Freenect2DeviceImpl] canceling rgb transfers...
[Info] [Freenect2DeviceImpl] canceling depth transfers...
[Info] [Freenect2DeviceImpl] stopped
[Info] [Freenect2DeviceImpl] closing...
[Info] [Freene
ct2DeviceImpl] releasing usb interfaces...
[Info] [Freenect2DeviceImpl] deallocating usb transfer pools...
[Info] [Freenect2DeviceImpl] closing usb device...
[Info] [Freenect2DeviceImpl] closed
[Info] [Freenect2DeviceImpl] already closed, doing nothing
From here, it shows there's some problem with the libva, however, I don't understand what the reminders mean. I used to be happy with the image and continue to work on the ROS. and the ROS results turn to be fairly disappointing!
I found a kinect ROS driver which is called iai-kinect2:
https://github.com/code-iai/iai_kinect2
And it fails when I run
roslaunch kinect2_bridge kinect2_bridge.launch
This is the main problem.(I want to show you the overall message from the screen, but sorry, I don't know how.) And it shows me no message and always shows some problems:
[Info] [OpenCLDepthPacketProcessorImpl] building OpenCL program...
[Error] [OpenCLDepthPacketProcessorImpl] program = cl::Program(context, source, &err): -34
[ WARN] [1489113544.030635869]: [Kinect2Bridge::initCalibration] using sensor defaults for color intrinsic parameters.
[ WARN] [1489113544.030691456]: [Kinect2Bridge::initCalibration] using sensor defaults for ir intrinsic parameters.
[ WARN] [1489113544.030714924]: [Kinect2Bridge::initCalibration] using defaults for rotation and translation.
[ WARN] [1489113544.030751568]: [Kinect2Bridge::initCalibration] using defaults for depth shift.
[ INFO] [1489113544.122475564]: [DepthRegistration::New] Using OpenCL registration method!
[ INFO] [1489113544.122519103]: [DepthRegistration::New] Using OpenCL registration method!
[ERROR] [1489113544.134612055]: [DepthRegistrationOpenCL::init] depth_registration_opencl.cpp cl::Platform::get(&platforms) failed: -1001
Any suggestions?
Originally posted by vcdanda on ROS Answers with karma: 38 on 2017-03-10
Comment by vcdanda on 2017-03-10:
The system tells me there's something wrong with the opencl. I will tell you the progress later. Anyone who has met the same problem are welcome to share their experience.
Comment by wangshuailpp on 2017-06-21:
Hi, Did you solve your problem ? I have the same problem,Can you help me ? Thank you very much!
Comment by Harsh2308 on 2018-10-30:
I have a similar problem though I am running this package kinect2_tracker, and on launching roslaunch kinect2_tracker tracker.launch I get,
libva info: VA-API version 0.39.4
libva info: va_getDriverName() returns -1
If it is really a opencl problem the why don't you try to run it without opencl at first? maybe this works: roslaunch kinect2_bridge kinect2_bridge.launch depth_method:=cpu
Originally posted by Kami with karma: 16 on 2017-04-19
