My problem is very similar to this other question: http://answers.ros.org/question/223792/roslaunch-turtlebot_gazebo-failure/ However it didn't seem like a solution was ever found so I thought I'd better ask my own question to get some answers.
I have installed ros indigo, gazebo, roslaunch packages and the gazebo turtlebot packages, using sudo apt-get. I have set up my environment using source /opt/ros/indigo/setup.bash. On the gazebo website I am told to run the turtlebot simulation using: roslaunch turtlebot_gazebo turtlebot_empty_world.launch
When I run that command I get the following error:
[turtlebot_empty_world.launch] is neither a launch file in package [turtlebot_gazebo] nor is [turtlebot_gazebo] a launch file name The traceback for the exception was written to the log file
In the question I have linked above the suggested solution was to instead use the command:
roslaunch turtlebot_gazebo turtlebot_world.launch
Running that command gives me a different error:
while processing /opt/ros/indigo/share/turtlebot_bringup/launch/includes/robot.launch.xml:
while processing /opt/ros/indigo/share/turtlebot_bringup/launch/includes/description.launch.xml:
Invalid tag: Cannot load command parameter [robot_description]: command [/opt/ros/indigo/share/xacro/xacro.py '/opt/ros/indigo/share/turtlebot_description/robots/kobuki_hexagons_asus_xtion_pro.urdf.xacro'] returned with code [1].
Param xml is
I am new to ROS and gazebo and any assistance would be appreciated. I also apologise for not knowing how to properly format my question; if anyone can tell me how to mark the error logs as code sections so that they are more readable I would be grateful.
Originally posted by UniversityStudent1701 on ROS Answers with karma: 16 on 2017-04-06
Solved the problem by deleting a custom version of python so that the default version would be used instead
Originally posted by UniversityStudent1701 with karma: 16 on 2017-04-16
