After Synaptic installation of ros-indigo-rocon and kabuki, I downloaded the turtlebot.rosinstall and did a rosdep install. next I added the source to .bashrc and executed. Then,
~/turtlebot$ sudo apt-get install ros-indigo-turtlebot ros-indigo-turtlebot-apps ros-indigo-turtlebot-interactions ros-indigo-turtlebot-simulator ros-indigo-kobuki-ftdi ros-indigo-rocon-remocon
My next command was:
:~/turtlebot$ roslaunch turtlebot_gazebo turtlebot_empty_world.launch
[turtlebot_empty_world.launch] is neither a launch file in package [turtlebot_gazebo] nor is [turtlebot_gazebo] a launch file name
The traceback for the exception was written to the log file**
When I reran the installation, I got:
ros-indigo-kobuki-ftdi is already the newest version.
ros-indigo-rocon-remocon is already the newest version.
ros-indigo-turtlebot is already the newest version.
ros-indigo-turtlebot-apps is already the newest version.
ros-indigo-turtlebot-interactions is already the newest version.
ros-indigo-turtlebot-simulator is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 215 not upgraded.
Can anyone suggest what I should do to recover?
What is the log file referred to in the error message?
Originally posted by ptreyesguy on ROS Answers with karma: 21 on 2016-01-11
Comment by marwa eldiwiny on 2016-08-05:
Me to I get the same error
[turtlebot_gazebo.launch] is neither a launch file in package [turtlebot_example] nor is [turtlebot_example] a launch file name The traceback for the exception was written to the log file
You should use this command:
roslaunch turtlebot_gazebo turtlebot_world.launch
There are some tutorials at http://wiki.ros.org/action/show/Robots/TurtleBot?distro=indigo in section 6 about bringing up the TurtleBot in gazebo.
Originally posted by nampi with karma: 77 on 2016-01-11
Comment by ptreyesguy on 2016-01-11:
Thank you nampi but using the command you specify does not work. I get the same error message again: **[turtlebot_world] is neither a launch file in package [turtlebot_gazebo] nor is [turtlebot_gazebo] a launch file name The traceback for the exception was written to the log file
Comment by nampi on 2016-01-11:
@ptreyesguy Try to type "roslaunch turtlebot_gazebo" in command line, then press 'Tab'. What launch files do you have?
**No result from Tab but "dpkg -l |grep gazebo" shows: ros-indigo- followed by, respectively gazebo2m concert-service-gazebo, indigo-gazebo-concert,gazebo-msgs, gazebo-plugins, gazebo-ros, gazebo-ros-control, gazebo-ros-pkgs, kabuki-gazebo-plugins, turtlebot-gazebo
Comment by nampi on 2016-01-12:
I have some of these packages and in addition I have "gazebo2", "ros-indigo-kobuki-gazebo" in output "dpkg -l | grep gazebo".
Comment by ptreyesguy on 2016-01-12:
nampi: Please tell me where your packages are, relative to HOME.
Comment by nampi on 2016-01-14:
My packages are situated here: /opt/ros/indigo/share. Also you can use command: "roscd". roscd allows you to change directories using a package name. Read more here http://wiki.ros.org/rosbash#roscd.
