Respected, I need to work on the concept of "libpcan". It is an entirely new topic and the possible sources i have found so far from where i can know and learn about this are as follows: http://wiki.ros.org/libpcan
http://www.care-o-bot.de/en/research.html (not sure whether the latter link will help me or not).
When i try to implement the "libpcan" from the link "http://wiki.ros.org/libpcan", i get the following error on using the command "sudo ./install_pcan.sh"
I am new to this field of libpcan and i am getting too many doubts and errors on this.
Regards
Originally posted by Ayush Sharma on ROS Answers with karma: 41 on 2017-02-15
Comment by ahendrix on 2017-02-17:
This question already has an answer that isn't related to build issues, and in general other users don't look at questions that are answered. Please post your build issue as a new question.
Comment by Ayush Sharma on 2017-02-17:
I tried but i failed to find the relevant solution. Probably some are present but are related to bring changes in the xml files to remove the error.
Unfortunately, i am unable to link them with my issue.
In case you have the sol. ,kindly let me know. I am trying to get started with any possible code with libpcan and other can drivers, but still unable to implement a basic "libpcan" reference section on ros site. If you have the solution, or u know the link to the solution, do let me know.
Regards
