Respected all, My task is to get the orientation sensor data from the phone and send it to the ROS for further processing.
I have decided to implement this via the following procedure: 1: Android App | 2: Bluetooth Shield | 3: Arduino (retrieving real time orientation data from android app) | 4: ROS (Rosserial)
I have implemented the first three steps and have retrieved the orientation data on arduino serial monitor on real time.
Now, when I am trying to use the serial_node.py (from the ros wiki), using the command:
rosrun rosserial_python serial_node.py _port:=/dev/ttyACM0 _baud:=9600
I am getting the following error! image description
This works well when I tried the conventional "Hello World" example of the rosserial. This means that the node files are working well. Also, i have use the command "nh.getHardware()-> setBaud(9600);" to set the baud rate.
Following is the code i am trying. (Please note that there can be manyy error in the code). I have edited the conventional "hello world" program and the arduino bluetooth code to get the orientation string
#include<SoftwareSerial.h>;
#include <ros.h>
#include <std_msgs/String.h>
ros::NodeHandle nh;
std_msgs::String str_msg;
ros::Publisher chatter("chatter", &str_msg);
SoftwareSerial myBT (11, 10);
const int ledPin = 13;
String inCode = "";
boolean endCode = false;
void setup () {
  Serial.begin(9600);
  pinMode (ledPin, OUTPUT);
  inCode.reserve (30);
  nh.initNode();
  nh.advertise(chatter);
void loop () {
  if (myBT.available ()) {
    char incomingChar = myBT.read ();
    if (incomingChar == ')') {
      endCode = true;
    else
      inCode  = (inCode + incomingChar);
  if (endCode) {
    int comma1 = inCode.indexOf (',');
    int comma2 = inCode.indexOf (',', comma1 + 1);
    String As = inCode.substring (0, comma1);
    String Ps = inCode.substring (comma1 + 1, comma2);
    String Rs = inCode.substring (comma2 + 1);
    Serial.print ("inCode =");
    Serial.print (inCode);
    Serial.print ("Azimuth =");
    Serial.print (As);
    Serial.print ("Pitch =");
    Serial.print (Ps);
    Serial.print ("Roll =");
    Serial.println (Rs);
    str_msg.data = 'As';
    chatter.publish( &str_msg );
    nh.spinOnce();
    delay(1000);
    int A = As.toInt ();
    int P = Ps.toInt ();
    int R = Rs.toInt ();
    inCode = "";
    endCode = false;
Why am i getting such errors? Kindly help. Regards
Originally posted by Ayush Sharma on ROS Answers with karma: 41 on 2017-06-17
Have you tried using rosserial_server instead of rosserial_python? For me this solved a big part of the problem. Seems like rosserial_python cannot handle the connections most of the times so it's safer to use the server mode.
You can check http://wiki.ros.org/rosserial_server.
Originally posted by thepirate16 with karma: 101 on 2017-06-25
Comment by Ayush Sharma on 2017-06-26:
Respected, I have tried the same earlier. But, no positive results!!!!
