Hello,
I'm working on a node with an internal state machine. The node has to run the main loop in the "running" state, then after using Ctrl+C (or sending a rosnode kill) switch into a "closing" state do some stuff (maybe ROS related, like publishing on a topic) and then shutdown completely. In synthesis, I need to break the main loop without using ros::shutdown().
Currently I'm using an implementation similar to the one suggested here: http://answers.ros.org/question/27655/what-is-the-correct-way-to-do-stuff-before-a-node-is-shutdown/
Is this one still the best (and probably only) approach? Or there is a way to "split" the shutdown procedure?
Originally posted by g.bardaro on ROS Answers with karma: 110 on 2016-12-22
http://answers.ros.org/question/27655/what-is-the-correct-way-to-do-stuff-before-a-node-is-shutdown/ Is still the best approach.
Originally posted by tfoote with karma: 58457 on 2016-12-22
Comment by g.bardaro on 2016-12-23:
I see, thank you.
Is there any future plan on extending the shutdown procedure and give to the developers more control over it?
