Hi all! In my project I'm spawning a thread which contains a while loop, simply like so:
std::thread worker([this]() { this->ballotCheckingThread(); });
std::unique_lock<std::mutex> lock(this->candidate_mutex_);
where the thread code is like this
void ballotCheckingThread() {
    while (!this->checkVotingCompleted() && !this->checkForExternalLeader()) {
        // Simulate some delay between checks
        std::this_thread::sleep_for(std::chrono::milliseconds(200));
    // Notify the first thread to stop waiting
    cv.notify_all();
Unfortunately, when I use CTRL-C to terminate the node, this thread remains hanging and I have to manually kill it.
Right now in the main function I'm doing this:
int main(int argc, char *argv[]) {
    std::cout << "Starting  node..." << std::endl;
    setvbuf(stdout, NULL, _IONBF, BUFSIZ);
    rclcpp::init(argc, argv);
    rclcpp::Node::SharedPtr node = std::make_shared<myNode>();
    rclcpp::executors::MultiThreadedExecutor executor;
    executor.add_node(node);
    try {
        executor.spin();
    } catch (std::exception& e) {
        std::cout << "rclcpp shutting down..." << std::endl;
        rclcpp::shutdown();
        return 0;
but I guess that's not enough. Is there a standard way to do this?
Originally posted by slim71 on ROS Answers with karma: 18 on 2023-07-17
In the end, I've found a solution. Using a global variable std::weak_ptr<MyNode> MyNode::instance_;, I've initialized it in the main and registered it as a signal handler:
// Set the instance pointer to the shared pointer of the main node
MyNode::setInstance(node);
// Register the signal handler for SIGINT (CTRL+C)
signal(SIGINT, MyNode::signalHandler);
before adding and spinning the node.
I had to add some function to the node, of course:
class MyNode : public rclcpp::Node {
    public:
        std::atomic<bool> is_terminated_ {false};
        void stopThread();
        void startThread();
        static void signalHandler(int signum);
        static std::shared_ptr<MyNode> getInstance();
        static void setInstance(rclcpp::Node::SharedPtr instance);
    private:
        std::thread helping_thread_;
        static std::weak_ptr<MyNode> instance_; // Weak pointer to the instance of the node
void MyNode::setInstance(rclcpp::Node::SharedPtr instance) {
    instance_ = std::static_pointer_cast<MyNode>(instance);
std::shared_ptr<MyNode> MyNode::getInstance() {
    return instance_.lock();
void MyNode::signalHandler(int signum) {
    // Stop the thread gracefully
    std::shared_ptr<MyNode> node = getInstance();
        if (node) {
            node->stopThread();
    rclcpp::shutdown();
void MyNode::startThread() {
    if (!this->helping_thread_.joinable()) {
        this->helping_thread_ = std::thread(&MyNode::spawnedThread, this);
void MyNode::stopThread() {
    if (this->helping_thread_.joinable()) {
        this->is_terminated_ = true;
        this->helping_thread_.join();
where spawnedThread is the main function used in the additional thread.
I don't really like using global variables and such, but for now this works as intended.
Originally posted by slim71 with karma: 18 on 2023-07-20
