I am unable to add multiple objects to MoveIt planning scene. Using the Move Group C++ API, I do:
moveit::planning_interface::PlanningSceneInterface planning_scene_interface;
moveit_msgs::CollisionObject co, co2;
Fill in the fields of moveit_msgs co & co2
co.operation = co.ADD;
co2.operation=co2.ADD;
std::vector<moveit_msgs::CollisionObject> collision_objects;
collision_objects.push_back(co);
collision_objects.push_back(co2) ;
ROS_INFO("Add an object into the world");
planning_scene_interface.addCollisionObjects(collision_objects);
sleep(2.0);
When I run it, only one collision object appears i.e. co2 .
I can not figure out what am I missing. Please help me out.
Originally posted by rohin on ROS Answers with karma: 99 on 2016-10-03
Hi Rohin,
Are you assigning unique id's to the CollisionObjects? Looking at the message type we can see that for the ADD operation, the CollisionObject information will be replaced if the object (with the id string as an identifier) is already present in the planningScene.
Originally posted by rbbg with karma: 1823 on 2016-10-03
Comment by rohin on 2016-10-03:
Yeah...
I was doing
co.header.frame_id = group.getPlanningFrame(); co2.header.frame_id = group.getPlanningFrame();
How should I assign different ID's?
Thanks! That solved it!
