I’m using the BMA020 (from ELV) with my Arduino Mega2560 and trying to read acceleration values that doesn’t confuse me. First I connected the sensor in SPI-4 mode. Means
CSB <-> PB0 (SS)
SCK <-> PB1 (SCK)
SDI <-> PB2 (MOSI)
SDO <-> PB3 (MISO)
Also GND and UIN are connected with the GND and 5V Pins of the Arduino board.
Here is the self-written code I use
#include <avr/io.h>
#include <util/delay.h>
#define sensor1     0
typedef int int10_t;
int TBM(uint8_t high, uint8_t low)
    int buffer = 0;
    if(high & (1<<7)) {
        uint8_t high_new = (high & 0x7F);
        buffer = (high_new<<2) | (low>>6);
        buffer = buffer - 512;
    else
        buffer = (high<<2) | (low>>6);
    return buffer;
void InitSPI(void);
void AccSensConfig(void);
void WriteByteSPI(uint8_t addr, uint8_t Data, int sensor_select);
uint8_t ReadByteSPI(int8_t addr, int sensor_select);
void Read_all_acceleration(int10_t  *acc_x, int10_t *acc_y, int10_t *acc_z, int sensor_select);
int main(void)
    int10_t S1_x_acc = 0, S1_y_acc = 0, S1_z_acc = 0;
    InitSPI();
    AccSensConfig();
    while(1) {
        Read_all_acceleration(&S1_x_acc, &S1_y_acc, &S1_z_acc, sensor1);
void InitSPI(void) {
    DDRB |= (1<<DDB2)|(1<<DDB1)|(1<<DDB0);
    PORTB |= (1<<PB0);
    SPCR |= (1<<SPE);
    SPCR |= (1<<MSTR);
    SPCR |= (0<<SPR0) | (1<<SPR1);
    SPCR |= (1<<CPOL) | (1<<CPHA);
void AccSensConfig(void) {
    WriteByteSPI(0x0A, 0x02, sensor1);
    _delay_ms(100);
    WriteByteSPI(0x15,0x80,sensor1);    //nur SPI4 einstellen
void WriteByteSPI(uint8_t addr, uint8_t Data, int sensor_select) {
    PORTB &= ~(1<<sensor_select);
    SPDR = addr;
    while(!(SPSR & (1<<SPIF)));
    SPDR = Data;
    PORTB |= (1<<sensor_select);
    int8_t dummy = 0xAA;
    SPDR = addr;
    SPDR = dummy;
    addr=SPDR;
    return addr;
    uint8_t addr = 0x82;
    uint8_t dummy = 0xAA;
    uint8_t high = 0;
    uint8_t low = 0;
    SPDR = addr;
    SPDR = dummy;
    low = SPDR;
    SPDR = dummy;
    high = SPDR;
    *acc_x = TBM(high, low);
    SPDR = dummy;
    low = SPDR;
    SPDR = dummy;
    high = SPDR;
    *acc_y = TBM(high, low);
    SPDR = dummy;
    low = SPDR;
    SPDR = dummy;
    high = SPDR;
    *acc_z = TBM(high, low);
And now here is what really confuses me. I got 5 of this sensors. One is working with this code perfectly fine. The Data I get is what I expect. I measure earth gravity in z-component if Iay the sensor on the table, if I start turning it I measure the earth gravity component wise in x-, y- and z- direction depending on the angle I turn the sensor.
From the other 4 sensors I receive data that is different. The values jump from -314 (about -1.2 g) to +160 (about 0.5g). With the same code, the same wires and the same Arduino.
I checked the register settings of all sensors, they are all the same. I checked the wire connection to the first component at the sensors, they are all around 0.3 Ohm. I used an Oscilloscope and made sure CSB, SCK and MOSI work properly.
Am I missing something? What causes this similar but wrong behavior of 4 out of 5 sensors?
Earlier answer, regarding the self-test
Section 3.3.2 describes how to do the self test, section 3.4.1 describes how to read the result.
There is a note about not overwriting bits 5, 6, and 7 of register 14h at the start of chapter 3, so read that and then check that you have scaling set correctly (bits 0 and 1 of register 14h).
As the chips that are suspect all also fail the self test and voltages on the board are normal, I would blame physical damage (were dropped/thrown during shipping, etc) and ask for an RMA for the parts.
A caution
While the board linked in the question accepts an input voltage of up to 6V, the board features a regulator and level shifters. The chip itself operates at a much lower voltage.
12
  • $\begingroup$ I left the register 14h untouched, but I read them out they are all the same. Like you said I performed the self_test_0 on every single device. They all failed beside the single sensor that delivers plausible data. What does a negative self-test means? Are my 4 out of 5 sensors broken? $\endgroup$
    – solid
    Jul 2, 2015 at 13:55
  • $\begingroup$ Note that the instructions for the self test say that you can't move the sensor while you're running the self test, but yes, if the self-test passes on the one that reads as expected and fails on the ones that don't, then I would say that they are broken. $\endgroup$
    – Chuck
    Jul 2, 2015 at 14:10
  • $\begingroup$ ACTUALLY I found your problem. See my edit above. $\endgroup$
    – Chuck
  • $\begingroup$ I disagree, the operating voltage for the chip is 2.0 to 3.6V, this is correct. I use the linked above circuit (shown on the German web page I couldn’t find an English one with this product) which has the BMA020 built in. The circuit provides a linear regulator to supply the BMA020 with round about 3V. The input at the UIN – pin of the circuit is specified with 2.5V to 6V. $\endgroup$
    – solid
    Jul 2, 2015 at 14:27
  • $\begingroup$ Can you probe Vin on the BMA020 boards? What voltage is present on the Arduino side on your signal pins when they're high? $\endgroup$
    – Chuck
    Jul 2, 2015 at 18:52
