hello every one, I am using the hector slam with hokuyo. i do have have the map but i need to see the path of the robot on Rviz can anyone help me please
Originally posted by aziz on ROS Answers with karma: 1 on 2016-05-22
To get the trajectory, you have to initialize hector_trajectory_server node.To do this you can directly call "geotiff_mapper.launch" file in "hector_geotiff" package. After launching this node, to visualize the path in rviz add "Path" and select topic as /trajectory.
Edit:
Working Launch files
hector_hokuyo.launch
<launch>
<param name="pub_map_odom_transform" value="true"/>
<param name="map_frame" value="map"/>
<param name="base_frame" value="base_frame"/>
<param name="odom_frame" value="odom"/>
<node pkg="hokuyo_node" type="hokuyo_node" name="hokuyo_node"/>
<node pkg="tf" type="static_transform_publisher" name="map_2_odom" args="0 0 0 0 0 0 /map /odom 100"/>
<node pkg="tf" type="static_transform_publisher" name="odom_2_base_footprint" args="0 0 0 0 0 0 /odom /base_footprint 100"/>
<node pkg="tf" type="static_transform_publisher" name="base_footprint_2_base_link" args="0 0 0 0 0 0 /base_footprint /base_link 100"/>
<node pkg="tf" type="static_transform_publisher" name="base_link_2_base_stabilized_link" args="0 0 0 0 0 0 /base_link /base_stabilized 100"/>
<node pkg="tf" type="static_transform_publisher" name="base_stablized_2_base_frame" args="0 0 0 0 0 0 /base_stabilized /base_frame 100"/>
<node pkg="tf" type="static_transform_publisher" name="base_frame_2_laser_link" args="0 0 0 0 0 0 /base_frame /laser 100"/>
<node pkg="tf" type="static_transform_publisher" name="base_2_nav_link" args="0 0 0 0 0 0 /base_frame /nav 100"/>
<node pkg="rviz" type="rviz" name="rviz" args="-d <path_to_folder>/rviz_cfg.rviz"/>
<include file="<path_to_folder>/default_mapping.launch"/>
<include file="<path_to_folder>/geotiff_mapper.launch"/>
</launch>
<launch>
<arg name="tf_map_scanmatch_transform_frame_name" default="scanmatcher_frame"/>
<arg name="base_frame" default="base_frame"/>
<arg name="odom_frame" default="base_frame"/>
<arg name="pub_map_odom_transform" default="true"/>
<arg name="scan_subscriber_queue_size" default="5"/>
<arg name="scan_topic" default="scan"/>
<arg name="map_size" default="2048"/>
<node pkg="hector_mapping" type="hector_mapping" name="hector_mapping" output="screen">
<!-- Frame names -->
<param name="map_frame" value="map" />
<param name="base_frame" value="$(arg base_frame)" />
<param name="odom_frame" value="$(arg odom_frame)" />
<!-- Tf use -->
<param name="use_tf_scan_transformation" value="true"/>
<param name="use_tf_pose_start_estimate" value="false"/>
<param name="pub_map_odom_transform" value="$(arg pub_map_odom_transform)"/>
<!-- Map size / start point -->
<param name="map_resolution" value="0.050"/>
<param name="map_size" value="$(arg map_size)"/>
<param name="map_start_x" value="0.5"/>
<param name="map_start_y" value="0.5" />
<param name="map_multi_res_levels" value="2" />
<!-- Map update parameters -->
<param name="update_factor_free" value="0.4"/>
<param name="update_factor_occupied" value="0.9" />
<param name="map_update_distance_thresh" value="0.4"/>
<param name="map_update_angle_thresh" value="0.06" />
<param name="laser_z_min_value" value = "-1.0" />
<param name="laser_z_max_value" value = "1.0" />
<!-- Advertising config -->
<param name="advertise_map_service" value="true"/>
<param name="scan_subscriber_queue_size" value="$(arg scan_subscriber_queue_size)"/>
<param name="scan_topic" value="$(arg scan_topic)"/>
<!-- Debug parameters -->
<param name="output_timing" value="false"/>
<param name="pub_drawings" value="true"/>
<param name="pub_debug_output" value="true"/>
<param name="tf_map_scanmatch_transform_frame_name" value="$(arg tf_map_scanmatch_transform_frame_name)" />
</node>
<!--<node pkg="tf" type="static_transform_publisher" name="map_nav_broadcaster" args="0 0 0 0 0 0 map nav 100"/>-->
</launch>
<launch>
<arg name="trajectory_source_frame_name" default="/scanmatcher_frame"/>
<arg name="trajectory_update_rate" default="4"/>
<arg name="trajectory_publish_rate" default="0.25"/>
<arg name="map_file_path" default="$(find hector_geotiff)/maps"/>
<arg name="map_file_base_name" default="hector_slam_map"/>
<node pkg="hector_trajectory_server" type="hector_trajectory_server" name="hector_trajectory_server" output="screen">
<param name="target_frame_name" type="string" value="/map" />
<param name="source_frame_name" type="string" value="$(arg trajectory_source_frame_name)" />
<param name="trajectory_update_rate" type="double" value="$(arg trajectory_update_rate)" />
<param name="trajectory_publish_rate" type="double" value="$(arg trajectory_publish_rate)" />
</node>
<node pkg="hector_geotiff" type="geotiff_node" name="hector_geotiff_node" output="screen" launch-prefix="nice -n 15">
<remap from="map" to="/dynamic_map" />
<param name="map_file_path" type="string" value="$(arg map_file_path)" />
<param name="map_file_base_name" type="string" value="$(arg map_file_base_name)" />
<param name="geotiff_save_period" type="double" value="0" />
<param name="draw_background_checkerboard" type="bool" value="true" />
<param name="draw_free_space_grid" type="bool" value="true" />
<param name="plugins" type="string" value="hector_geotiff_plugins/TrajectoryMapWriter" />
</node>
</launch>
rviz_cfg.rviz
Panels:
- Class: rviz/Displays
Help Height: 78
Property Tree Widget:
Expanded:
- /Global Options1
- /Status1
- /LaserScan1
- /Map1
- /Path1
Splitter Ratio: 0.5
Tree Height: 463
- Class: rviz/Selection
- Class: rviz/Tool Properties
Expanded:
- /2D Pose Estimate1
- /2D Nav Goal1
- /Publish Point1
Name: Tool Properties
Splitter Ratio: 0.588679
- Class: rviz/Views
Expanded:
- /Current View1
Splitter Ratio: 0.5
- Class: rviz/Time
Experimental: false
SyncMode: 0
SyncSource: LaserScan
Visualization Manager:
Class: ""
Displays:
- Alpha: 0.5
Cell Size: 1
Class: rviz/Grid
Color: 160; 160; 164
Enabled: true
Line Style:
Line Width: 0.03
Value: Lines
Normal Cell Count: 0
Offset:
X: 0
Y: 0
Z: 0
Plane: XY
Plane Cell Count: 10
Reference Frame: <Fixed Frame>
Value: true
- Alpha: 1
Autocompute Intensity Bounds: true
Autocompute Value Bounds:
Max Value: 0
Min Value: 0
Value: true
Axis: Z
Channel Name: intensity
Class: rviz/LaserScan
Color: 255; 255; 255
Color Transformer: AxisColor
Decay Time: 0
Enabled: true
Invert Rainbow: false
Max Color: 255; 255; 255
Max Intensity: 4096
Min Color: 0; 0; 0
Min Intensity: 0
Position Transformer: XYZ
Queue Size: 10
Selectable: true
Size (Pixels): 3
Size (m): 0.01
Style: Points
Topic: /scan
Unreliable: false
Use Fixed Frame: true
Use rainbow: true
Value: true
- Class: rviz/TF
Enabled: true
Frame Timeout: 15
Frames:
All Enabled: true
base_footprint:
Value: true
base_frame:
Value: true
base_link:
Value: true
base_stabilized:
Value: true
laser:
Value: true
map:
Value: true
nav:
Value: true
odom:
Value: true
scanmatcher_frame:
Value: true
Marker Scale: 1
Show Arrows: true
Show Axes: true
Show Names: true
Tree:
map:
odom:
base_footprint:
base_link:
base_stabilized:
base_frame:
laser:
nav:
scanmatcher_frame:
Update Interval: 0
Value: true
- Alpha: 0.7
Class: rviz/Map
Color Scheme: map
Draw Behind: false
Enabled: true
Topic: /map
Unreliable: false
Value: true
- Alpha: 1
Buffer Length: 1
Class: rviz/Path
Color: 255; 0; 0
Enabled: true
Line Style: Lines
Line Width: 0.03
Offset:
X: 0
Y: 0
Z: 0
Topic: /trajectory
Unreliable: false
Value: true
Enabled: true
Global Options:
Background Color: 48; 48; 48
Fixed Frame: map
Frame Rate: 30
Tools:
- Class: rviz/Interact
Hide Inactive Objects: true
- Class: rviz/MoveCamera
- Class: rviz/FocusCamera
- Class: rviz/Measure
- Class: rviz/SetInitialPose
Topic: /initialpose
- Class: rviz/SetGoal
Topic: /move_base_simple/goal
- Class: rviz/PublishPoint
Single click: true
Topic: /clicked_point
Value: true
Current:
Class: rviz/Orbit
Distance: 12.776
Enable Stereo Rendering:
Stereo Eye Separation: 0.06
Stereo Focal Distance: 1
Swap Stereo Eyes: false
Value: false
Focal Point:
X: 0.207938
Y: 1.02128
Z: -0.964317
Near Clip Distance: 0.01
Pitch: 1.5698
Target Frame: <Fixed Frame>
Value: Orbit (rviz)
Yaw: 4.7004
Saved: ~
Window Geometry:
Displays:
collapsed: false
Height: 744
Hide Left Dock: false
Hide Right Dock: false
QMainWindow State: 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
Selection:
collapsed: false
Time:
collapsed: false
Tool Properties:
collapsed: false
collapsed: false
Width: 1301
X: 65
Y: 24
Originally posted by gp with karma: 166 on 2016-05-24
Comment by aziz on 2016-05-24:
I did what you told me but i still don't have the path, do i need to set any parameter on "geotiff_mapper.launch" file ?
Comment by gp on 2016-05-25:
Can you please share your launch files or elaborate what procedure you are following. In "geotiff_mapper.launch" file, you will need to set argument "trajectory_source_frame_name" to tf for which you want to visualize the path.
Comment by aziz on 2016-06-09:
its working , thank you a lot , you saved me
Comment by gp on 2016-06-09:
You are welcome.
hey accept the answer as correct by clicking the tick mark :)
