I am trying to install the ackermann vehicle package from the main repository using
sudo apt-get install ros-indigo-ackermann-vehicle
However, I am getting a 404 error
Err http://packages.ros.org/ros/ubuntu/ trusty/main ros-indigo-ackermann-vehicle-description amd64 0.1.3-1trusty-20151201-0505-+0000 404 Not Found Err http://packages.ros.org/ros/ubuntu/ trusty/main ros-indigo-ackermann-vehicle-gazebo amd64 0.1.3-1trusty-20151201-1323-+0000 404 Not Found Err http://packages.ros.org/ros/ubuntu/ trusty/main ros-indigo-ackermann-vehicle amd64 0.1.3-1trusty-20151201-1326-+0000 404 Not Found E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-indigo-ackermann-vehicle-description/ros-indigo-ackermann-vehicle-description_0.1.3-1trusty-20151201-0505-+0000_amd64.deb 404 Not Found
E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-indigo-ackermann-vehicle-gazebo/ros-indigo-ackermann-vehicle-gazebo_0.1.3-1trusty-20151201-1323-+0000_amd64.deb 404 Not Found
E: Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-indigo-ackermann-vehicle/ros-indigo-ackermann-vehicle_0.1.3-1trusty-20151201-1326-+0000_amd64.deb 404 Not Found
Is this package still maintained in Indigo? or is it obsolete?
Thanks,
Originally posted by Oded on ROS Answers with karma: 105 on 2016-03-13
It looks like your apt-cache is out of date, and it's trying to download a previous version of the package.
Try updating your apt cache before installing:
sudo apt-get update
Originally posted by ahendrix with karma: 47576 on 2016-03-13
Comment by Oded on 2016-03-13:
After updating the apt-cache (apt-get update) the ackermann-vehicle has disappeared, i.e. now I get after
E: Unable to locate package ros-indigo-ackermann-vehicle
Comment by gvdhoorn on 2016-03-13:
(1/3) I'm not sure what happened, but the ackermann_* pkgs came out of wunderkammer, and some time ago all of it was deleted. The ROS Index page shows some info.
(2/3) The github organisation also seems to have been removed. here is the original announcement of the packages.
(3/3) And apparently jbpassot/ackermann_vehicle is a fork (which seems like it is the 'top fork' at the moment).
Comment by ahendrix on 2016-03-13:
It looks like the package was removed by the author: https://github.com/ros/rosdistro/commit/4630294aee35d3df3200e58ef1de178fdbe89e1d
Yeah, that's when I noticed it. Does anyone know why?
Btw: here is a (random) fork of steered_wheel_base_controller.
Hm, from the rosdistro PR:
tfoote wrote:
Would it be possible to put a copy of these repos in another organization for archival access?
jim-rothrock:
Sorry, but no, that would defeat the purpose of deleting the repositories.
