Hi
I'm having trouble installting ros indigo on Ubuntu 14.04. I've followed all of the instructions on this page, but when I run sudo apt-get install ros-indigo-desktop-full I get the following errors:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 ros-indigo-desktop-full : Depends: ros-indigo-desktop but it is not going to be installed
                           Depends: ros-indigo-simulators but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I've narrowed the problem down, it won't install because it can't find the package ros-indigo-urdfdom-headers:
user@computer:/etc/apt$ sudo apt-get install ros-indigo-urdfdom-headers
Package ros-indigo-urdfdom-headers is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'ros-indigo-urdfdom-headers' has no installation candidate
Is there a solution to this?
Thanks
Jamie
Originally posted by James Diprose on ROS Answers with karma: 123 on 2014-07-09
Comment by syrnick on 2014-07-09:
I'm seeing the same issue when re-provisioning my VM (https://github.com/ros-chef/ros-web-dev-vm, see the quickstart section to reproduce).
Comment by tfoote on 2014-07-09:
What are your apt sources?
Comment by syrnick on 2014-07-09:\
vagrant@ros-web-dev:~$ sudo cat /etc/apt/sources.list.d/ros-indigo.list
deb     http://packages.ros.org/ros/ubuntu trusty main
I'm not sure of a solution, but this might be related to rosdistro/issue/4633.
Originally posted by gvdhoorn with karma: 86574 on 2014-07-09
There appears to have been in issue with the ftp mirror syncing. I'm looking into it now. I'll track it on the above ticket.
Comment by fergs on 2014-07-09:
There isn't even a folder for http://packages.ros.org/ros/ubuntu/pool/main/r/ros-indigo-urdfdom -- it looks like urdfdom and headers are gone from public as well.
I had the same problem and found out that it's due to manual installation of Gazebo before ros installation. So i tried
sudo apt-get remove gazebo-* sdformat-*
and it helped.
Comment by petermitrano on 2014-12-28:
Seems you need to run this if you installed gazebo 4 before, then realized you need to remove it to install ROS. I ran this after running sudo apt-get remove gazebo4 and it allowed me install ros. Thanks!
