I finished base_link → odom tf like this
map
odom
base_link
But in another required tf transform, it reads
(the frame attached to incoming scans) → base_link usually a fixed value, broadcast periodically by a robot_state_publisher, or a tf static_transform_publisher.
(http://wiki.ros.org/gmapping)
I can not understand how to build tf: scan→ base_link , and depthimagine_to_laserscan(I use kinect) do not provide any tf Transform.
And tf transforms in Turtlebot like this:
map
odom
base_link
---------camera_rgb_frame-------
camera_depth_frame camera_link camera_rgb_optical_frame
camera_depth_optical_frame
So, how can I combine scan data to base_link and broadcast this tf like turtlebot?
Some keywords like "camera_depth_frame", "camera_link"... Broadcasting them direct without any define or export?
And my kinect is fixed on the underpan, does it need a URDF file, or just use static_transform_publisher is fine?
Sincerely
Originally posted by Bill Gates on ROS Answers with karma: 28 on 2015-12-22
