Hi
I faced this error: "roscd: command not found" same as rosnode except for roscore.
I have already setup my .bashrc by "source /opt/ros/jade/setup.bash"
Thanks
Originally posted by Reza1984 on ROS Answers with karma: 70 on 2015-12-09
Did you check these?;
http://answers.ros.org/question/195052/command-not-found-roscd-rosnode-etc/ http://answers.ros.org/question/66913/roscd-command-not-found-in-groovy-1204/
Also you can check your environment variables.
Originally posted by Akif with karma: 3561 on 2015-12-10
Comment by Reza1984 on 2015-12-10:
Yes I have checked all the possible solutions in the net but none of them worked.
Comment by Akif on 2015-12-10:
Can you check printenv | grep ROS output?
Comment by Reza1984 on 2016-03-03:
Sorry for late reply. I have installed ROS again and it works now.
Comment by Akif on 2016-03-03:
Glad you solved it.
