Hi there I'm new in working with ROS. I'm trying to create a package by the following command:
roscreate-pkg beginner_tutorials std_msgs rospy roscpp
but I get the following error
roscreate-pkg: command not found
I appreciate if you help me.
Originally posted by Reza1984 on ROS Answers with karma: 70 on 2013-11-06
Comment by BennyRe on 2013-11-06:
Do other ROS bash command work? Like roscd/rosmsg/...
Comment by Reza1984 on 2013-11-06:
Yes, but rospack and roscreate-pkg doesn't work. Btw I'm working with fuerte in ubuntu 12.04
Did you source the setup.bash?
Thanks aloooot, I forgot to do it!
Ok great I'll post it as an answer, so you can accept it.
Comment by meriemm on 2015-04-17:
hi,i have the same problem i have add the " source /opt/ros/hydro/setup.bash source ~/hydro_workspace/sandbox/setup.bash " but i still have the same problem,can you please help me.
Source your setup.bash
You may want to put this in your .bashrc
Originally posted by BennyRe with karma: 2949 on 2013-11-06
Comment by BennyRe on 2015-04-20:
Sourcing two setup.bash makes no sense. The first source gets overwritten by the second one. Have you set up your workspace correctly?
