Hi,
I am currently working on simulations of UAVs (for now I assume those UAVs are all quadrotors).
I am using hector_quadrotor so I have basically working quadrotor which is listening on cmd_vel topic and receives geometry_msgs/Twist message. I can control quadrotor just fine publishing those messages. But now I wan't to fly it autonomously.
I already have some global planner implemented from other project so I have trajectory with waypoints. What I wan't now is to give the waypoint to UAV and from there generate geometry_msgs/Twist (use some 3D local planner for motion) for UAV to move in simulation.
Is there already some local planner for this or should I write my own? And if there is no local planner, what should I learn to be able to write it? I am currently studying on University, but I am at the beginning so I don't have needed knowledge.
Thank you for any suggestions.
Edit: Or as I said, I can write it on my own. I wan't to learn how to do that. But I need some clue what to do and where to look. Maybe what kind of book should I read or something.
Edit2: I only wan't to be able to do that in simulation. So basically I don't have to solve problem with location of UAV itself yet. So I have UAV, I have it's position and I have given waypoint and I wan't to fly to that waypoint autonomously.
Originally posted by l4ncelot on ROS Answers with karma: 826 on 2015-09-21
