Hi
I was trying to build "hector_quadrotor_tutorial" by "catkin_make". Under worksapce directory, I enterned
catkin_make
it shows
CMake Error at /opt/ros/indigo/share/catkin/cmake/catkinConfig.cmake:75 (find_package):
Could not find a package configuration file provided by"gazebo_ros_control" with any of the following names:
gazebo_ros_controlConfig.cmake
gazebo_ros_control-config.cmake
Add the installation prefix of "gazebo_ros_control" to CMAKE_PREFIX_PATH or
set "gazebo_ros_control_DIR" to a directory containing one of the abovefiles.  If "gazebo_ros_control" provides a separate development package orSDK, be sure it has been installed.
hector_quadrotor/hector_quadrotor_controller_gazebo/CMakeLists.txt:7 (find_package)
See also "/home/xiaohao/hector_quadrotor_tutorial/build/CMakeFiles/CMakeOutput.log".
See also "/home/xiaohao/hector_quadrotor_tutorial/build/CMakeFiles/CMakeError.log".
make: *** [cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
I already tried
source /devel/setup.bash
I'm not sure how it goes wrong. Any advice aprreciated!
Originally posted by Glen on ROS Answers with karma: 40 on 2015-06-03
its been solved in two steps,
  1. reinstall libsdformat1.Because I removed "libsdformat" when I was trying to install sdformat.
    $ sudo apt-get install libsdformat1
  2. install unmet packages
    $ sudo apt-get install ros-indigo-gazebo-ros-control
Originally posted by Glen with karma: 40 on 2015-06-04
Comment by naveed on 2018-06-07:
I have a similar problem but your solution didnt work for me. Any other tips ?
Well, for the hydro disto you need to install the following package:
sudo apt-get install ros-hydro-gazebo-ros-control
Originally posted by angelos.p with karma: 148 on 2015-06-26
