My goal is to simulate the flight of a UAV in an outdoor environment. My preliminary steps are to see what ROS packages exist which I can reuse, and determine what I need to write myself.
I've looked for projects which have overlap with mine:
However I'm still trying to figure out how the following topics fit together:
  • SLAM
  • OctoMap
  • Path Planning
I'm not sure how they're intertwined, so I have several questions for experts out there:
OctoMap
  • Is it only good for generating 3D probabilistic maps? Does it offer solutions for localization? Or is that out of scope?
  • Is it capable of efficiently representing large geometric areas as obstacles? For example if I have a house I want to avoid, can I place a large rectangular prism in the map?
  • Does it have support for dynamic obstacles? For example other drones or moving vehicles?
  • Are octomaps even necessary for mobile drone applications (or outdoor applications in general)? Do people roll their own mapping solutions or does everyone use octomap?
  • Is there a certain data type (or sensor type) that the octomap supports or requires? What if I have sonar, RGBD, LIDAR, monocular camera, etc.?
  • What if an octomap gets too big? Is it possible to have a moving window filter around an area of interest (i.e. the drone) and "forget" the rest of the map (or dump to disk)?
Path Planning
  • Can I view path planning as a function which takes in an octomap and returns a 3D path according to the planner algorithm?
SLAM
  • Does a SLAM algorithm populate the octomap? Or does the SLAM algorithm work off the existing octomap and sensor data? What does this workflow look like?
Originally posted by triantatwo on ROS Answers with karma: 237 on 2015-11-17
Post score: 8
Comment by Anurag on 2016-09-27:
Could you find answer to this question? A good answer to this question will greatly help me. Thank you.
Hello, triantatwo!
Excellent question(s)! I realize that the question is fairly old, but I will try to give my best to answer it since it may help others.
OctoMap
  • OctoMap is good for several reasons. It is, as you said, probabilistic mapping procedure which allows us to integrate our measurements with a certain probability and to account for sensor noise and outliers. Furthermore, it is very memory efficient and relatively fast (depending on your requirements and number of points you want to integrate in one step). It is a multi-resolution mapping procedure, which means that you can see multiple resolutions in a map. By changing the resolution and range of your measurements you can also get a significant speedup etc. A very important thing to realize about OctoMap is the ray casting it does. It allows for the distinction between unknown, free and occupied voxels which some other mapping procedures do not have (point clouds, elevation maps, and multi-level surface maps). The important thing to notice is that OctoMap is a mapping procedure! Therefore, an odometry or SLAM algorithm needs to be present in order to populate the OctoMap correctly. As far as I know, no solution for localization is present although you could probably write your own localization algorithm. The OctoMap author mentioned it here.
  • Well, I would say that efficiency is mostly related to the resolution of the OctoMap. Of course, number of points to be integrated into a single measurement also plays a big role.
  • Dynamic obstacles are where the probability kicks in. Based on the values of probability for a "hit" and "miss" in the sensor model you could control the speed at which you are adding obstacles to your OctoMap. Everything with a probability over 0.5 is seen as an obstacle so if your probability of a hit is high dynamic obstacles will be added to the map relatively quickly - depends of course on the consistency of your sensor measurements. In theory, it works, but in practice, I could never get the desired behavior because of the sensor measurements inconsistency.
  • Of course, OctoMaps are not necessary! There are many other mapping procedures that could be used. It mostly depends on your requirements - speed, memory, sparse, semi-dense or dense mapping etc.
  • In order to map an environment and represent it with an OctoMap, you need some kind of a 3D information. If you have sonar you would get a point cloud and could easily insert it into an OctoMap. Same goes for RGBD sensors (Kinect, RealSense, ASUS Xtion) and LIDARs. If you have a monocular camera, there is no way of getting a 3D points of the image directly. You would have to use additional algorithms in order to create a point cloud from several RGB images.
  • If an OctoMap gets too big, you could just delete it and start over. Although I suppose it is not the solution you were aiming for. There is also a possibility to create a local map of the environment i.e. a bounding box around a drone and forget everything outside that box.
There are some extensions for OctoMaps that should enhance its performance like this.
Moreover, a new article on algorithm SkiMap that compares itself to the OctoMap and even states better performance is available online together with ROS implementation.
Path Planning
  • Generally speaking, yes. Path planning would be a module that would take in some kind of a map and plan the path according to the set of requirements - shortest path, most secure path etc. Usually, one would take an OctoMap, create an occupancy grid based on it and run a path planning/navigation packages on top of it. Since I have no experience in 3D path planning/navigation I have googled some posts that could be useful:
SLAM
  • As I've said before, you will need a SLAM or odometry algorithm in order to correctly build your OctoMap. The workflow could be something as follows: We have a drone equipped with IMU, GPS, and a monocular camera. Based on sensor information it calculates odometry (GPS, IMU and visual odometry using RGB camera) and tracks its position in the environment. At the same time, since it knows its position, it can map the environment relative to that position. If you know the position and have a point cloud at that position, the OctoMap mapping will easily insert it into the map.
However, one thing to note here! The OctoMap has no support for global optimization which occurs when loop closure is done. The map stays as it is! Furthermore, because of the drift in the odometry, the map can overlap between multiple frames. Therefore, you have to have good odometry algorithm to avoid it or, forget previously visited parts of the map by having a bounding box around a robot.
Since this is already a relatively long answer, I will stop here and if someone has any further questions feel free to ask.
If someone notices mistakes or some pieces of outdated information, please notify/correct me.
Originally posted by dljubic with karma: 516 on 2018-05-27
Post score: 23
Comment by aaditya_saraiya on 2018-05-30:
Thanks for a detailed review!
Comment by triantatwo on 2018-05-31:
It has been a while... I had to reset my password just to log in and vote for this excellent answer. Thank you!
Comment by haritsahm on 2020-01-23:
Do you have the example on creating a local map like setting a box around the drone using OctoMap?
Comment by dljubic on 2020-02-03:
Hello @haritsahm. I do, but unfortunatelly, I can not share it publicly. :/
