I'm following the Raspberry Pi Indigo installation guide here: http://wiki.ros.org/ROSberryPi/Installing%20ROS%20Indigo%20on%20Raspberry%20Pi
CMake is failing on the last step with this error: http://i.imgur.com/P9l5Gnr.jpg
==> Processing catkin package: 'ecl_time'
==> Building with env: '/opt/ros/indigo/env.sh'
==> cmake /home/pi/ros_catkin_ws/src/ecl_core/ecl_time -DCATKIN_DEVEL_PREFIX=/home/pi/ros_catkin_ws/devel_isolated/ecl_time -DCMA
-- Using CATKIN_DEVEL_PREFIX: /home/pi/ros_catkin_ws/devel_isolated/ecl_time
-- Using CMAKE_PREFIX_PATH: /opt/ros/indigo
-- This workspace overlays: /opt/ros/indigo
-- Using PYTHON_EXECUTABLE: /usr/bin/python
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/pi/ros_catkin_ws/build_isolated/ecl_time/test_results
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.6.14
CMake Error at /opt/ros/indigo/share/ecl_build/cmake/ecl_cx11.cmake:17 (message):
  Requested cxx11 flags, but this compiler does not support it.
  CMakeLists.txt:40 (ecl_enable_cxx11_compiler)
<== Failed to process package 'ecl_time':
  Command '['/opt/ros/indigo/env.sh', 'cmake', '/home/pi/ros_catkin_ws/src/ecl_core/ecl_time', '-DCATKIN_DEVEL_PREFIX=/home/pi/ros']' returned non-zero exit status 1
Reproduce this error by running:
==> cd /home/pi/ros_catkin_ws/build_isolated/ecl_time && /opt/ros/indigo/env.sh cmake /home/pi/ros_catkin_ws/src/ecl_core/ecl_timelease -G 'Unix Makefiles'
Command failed, exiting.
I'm not sure how to correct this.
Originally posted by gsav55 on ROS Answers with karma: 1 on 2015-09-11
Comment by gvdhoorn on 2015-09-11:
Please copy/paste console output into your question text: if your image ever gets deleted / the host dies, this question (and future answer) will be useless.
Be sure to format console text using the preformatted text button (the one with 101010 on it).
Comment by gsav55 on 2015-09-11:
I edited it. It seems to be coming from
but I don't know how to correct it.
I get the same problem. Deleting the ecl_time package doesn't help because other packages depends on it. Last June I compiled it without problems. Any help please
Mauro
Originally posted by Mauro with karma: 16 on 2015-09-30
Comment by Mauro on 2015-09-30:
The problem seems resolved. I substituted the ecl_time and ecl_devices folders with the ones in release 0.61.0 Sept 2014 and it compiles.
Mauro
