Hello,
i did the SLAM Map Building with TurtleBot,got a map( width :576,height:512) and a yaml file that goes with my pgm map. Its resolution is 0.05,but the SBPL Lattice planner has a map resolution 0.025, i want to change my map's resolution is 0.025.There has been a similar problem .
Question: what should i do to my pgm map with the gimp software to change my pgm map's resolution?
Thanks for your help !!
Originally posted by jxl on ROS Answers with karma: 252 on 2015-03-08
