hi i try to install this package and i dont know how run it http://sourceforge.net/p/usarsimros/code/ci/master/tree/usarsim_inf/
i try
~$ roslaunch usarsim_inf usarsim.launch
[usarsim.launch] is neither a launch file in package [usarsim_inf] nor is [usarsim_inf] a launch file name
The traceback for the exception was written to the log file
Originally posted by ksmksam on ROS Answers with karma: 13 on 2014-12-05
Comment by Aarif on 2014-12-09:
Did you make that usarsim_inf package??
it seems that you have not make(Compile) your usarsim_inf package. follow these steps to make the usarsim_inf package:-
  1. Go into the usarsim_inf folder using cd command
  2. set the environment variable path using this command:
    export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:pwd
  3. run the following command:
     rosmake usarsim_inf
then verify your package is successfully made or not by following command:
rospack find usarsim_inf
it will show the path of your folder and then you will be able to use this package.
Originally posted by Aarif with karma: 351 on 2014-12-17
