Hello,
I recently released a new version of a meta-package using the updated bloom 0.5.13 version. Since the update the souredeb Jenkins job has been repeatedly failing.
Here are the errors being displayed in the Jenkins console output:
dpkg-source: error: syntax error in ros-indigo-multisense-3.3.7/debian/control at line 10: block lacks the 'Package' field
dpkg-buildpackage: error: dpkg-source -i -I --before-build ros-indigo-multisense-3.3.7 gave error exit status 25
debuild: fatal error at line 1350:
dpkg-buildpackage -rfakeroot -d -us -uc -i -I -S failed
gbp:error: debuild -i -I returned 29
gbp:error: Couldn't run 'debuild -i -I -S -uc -us --lintian-opts --suppress-tags newer-standards-version'
Usage: include_folder.py [options]
The full console output can be found here: http://jenkins.ros.org/job/ros-indigo-multisense_sourcedeb/93/console
Here is the relese repository: https://github.com/carnegieroboticsllc/multisense_ros-release
Can anyone confirm these error are not caused by a incorrect package configuration? Also is there any documentation on the build process Jenkins is using to create the package debians?
Thanks, Matt Alvarado
Originally posted by malvaradoCRL on ROS Answers with karma: 15 on 2014-11-26
