Hello, I installing the ros groovy on ubuntu 12.04 following the wiki page http://wiki.ros.org/groovy/Installation/UbuntuARM
I have steup the sources.list and the keys. Then $sudo apt-get update
always show: W:Failed to fetch http://packages.namniart.com/repos/ros/dists/precise/Release
.In fact, the website can be open.If I install the ros ignore the problem,
$sudo apt-get install ros-groovy-ros-base it will show :
E:unable to locate packages ros-groovy-ros-base`
Please help me slove the problem,thank you very much.
Detailed process is as follows:
Hit http://packages.namniart.com precise Release.gpg
Hit http://ports.ubuntu.com precise Release.gpg
Get:1 http://ports.ubuntu.com precise-security Release.gpg [198 B]
Get:2 http://ports.ubuntu.com precise-updates Release.gpg [198 B]
Get:3 http://ports.ubuntu.com precise-security Release.gpg [198 B]
Get:4 http://ports.ubuntu.com precise-updates Release.gpg [198 B]
Get:5 http://ports.ubuntu.com precise-security Release [50.7 kB]
Get:6 http://ports.ubuntu.com precise-updates Release [98.7 kB]
Get:7 http://ports.ubuntu.com precise-security Release [50.7 kB]
Get:8 http://ports.ubuntu.com precise-updates Release [98.7 kB]
Hit http://ports.ubuntu.com precise/main Sources
Hit http://ports.ubuntu.com precise/universe Sources
Hit http://ports.ubuntu.com precise/main armel Packages
Hit http://ports.ubuntu.com precise/universe armel Packages
Hit http://ports.ubuntu.com precise/main TranslationIndex
Hit http://ports.ubuntu.com precise/universe TranslationIndex
Get:9 http://ports.ubuntu.com precise-security/main Sources [112 kB]
Get:10 http://ports.ubuntu.com precise-security/universe Sources [33.0 kB]
Get:11 http://ports.ubuntu.com precise-security/main armel Packages [328 kB]
Get:12 http://ports.ubuntu.com precise-security/universe armel Packages [89.1 kB]
Get:13 http://ports.ubuntu.com precise-security/main TranslationIndex [74 B]
Get:14 http://ports.ubuntu.com precise-security/universe TranslationIndex [73 B]
Get:15 http://ports.ubuntu.com precise-updates/main Sources [479 kB]
Get:16 http://ports.ubuntu.com precise-updates/universe Sources [111 kB]
Get:17 http://ports.ubuntu.com precise-updates/main armel Packages [698 kB]
Get:18 http://ports.ubuntu.com precise-updates/universe armel Packages [229 kB]
Get:19 http://ports.ubuntu.com precise-updates/main TranslationIndex [3564 B]
Get:20 http://ports.ubuntu.com precise-updates/universe TranslationIndex [2850 B]
Get:21 http://ports.ubuntu.com precise-security/main armel Packages [328 kB]
Get:22 http://ports.ubuntu.com precise-security/universe armel Packages [89.1 kB]
Get:23 http://ports.ubuntu.com precise-security/main TranslationIndex [74 B]
Get:24 http://ports.ubuntu.com precise-security/universe TranslationIndex [73 B]
Get:25 http://ports.ubuntu.com precise-updates/main armel Packages [698 kB]
Get:26 http://ports.ubuntu.com precise-updates/universe armel Packages [229 kB]
Get:27 http://ports.ubuntu.com precise-updates/main TranslationIndex [3564 B]
Get:28 http://ports.ubuntu.com precise-updates/universe TranslationIndex [2850 B]
Hit http://ports.ubuntu.com precise/main Translation-en
Hit http://ports.ubuntu.com precise/universe Translation-en
Hit http://ports.ubuntu.com precise-security/main Translation-en
Hit http://ports.ubuntu.com precise-security/universe Translation-en
Hit http://ports.ubuntu.com precise-updates/main Translation-en
Get:29 http://ports.ubuntu.com precise-updates/universe Translation-en [145 kB]
Get:30 http://ports.ubuntu.com precise-updates/universe Translation-en [145 kB]
Fetched 4025 kB in 46s (86.0 kB/s)
W: Failed to fetch http://packages.namniart.com/repos/ros/dists/precise/Release Unable to find expected entry 'main/binary-armel/Packages')
E: Some index files failed to download. They have been ignored, or old ones used instead.
Reading package lists... Done
Building dependency tree
E: Unable to locate package ros-groovy-ros-base
Originally posted by Alice63 on ROS Answers with karma: 63 on 2014-10-28
Comment by gvdhoorn on 2014-10-28:
I'm getting a 404 on the namniart URL as well. @ahendrix?
Comment by ahendrix on 2014-10-28:
That's funny.. it's trying to retrieve Release.In, when the filename should probably be InRelease. I'll do a little digging and see if I can figure out why that's happening.
Scratch that; it was just a formatting error in the question.
