Hello,
I have a non holonomic robot, "Seekur Jr." I set up the navigation stack, and I am using TrajectoryPlannerROS as a base local planner, with DWA set to true.
The path planning and obstacle avoidance works just fine , but when it moves the robot shows an incorrect behavior: When I set the goal to the right of the robot, it first makes a full turn to the left and then starts moving towards the goal. However when I set the goal to the left or in front of it, it goes directly there. So it seems the robot always needs to make a left turn first.
I debugged every part of the project(acml, odom,transformation) and the error doesn't seem to be related to them. I also checked all the parameters and matched them to the default parameters.
I have started to tune the parameters and I believe the error is caused by them however I am not sure which parameter to adjust. I have already followed a tuning guide and used all the default parameters.
I also tried all the solutions on the internet but non worked or solved my problem.
Please guide me on this issue. I have already spent close to two months trying to figure it out.
I'd be glad and thankful to your suggestions.
Originally posted by AmiraJr on ROS Answers with karma: 28 on 2014-08-10
Comment by jorge on 2014-08-11:
Which ROS version are you using? With the turtlebot indigo code this doesn't happen anymore, but I have no hydro installed, so I cannot check.
Comment by AmiraJr on 2014-08-12:
@jorge That was the problem , I had to set the min_vel_theta to -1.0. Thank you so much, you saved the project
Comment by jorge on 2014-08-12:
Cool. I make an answer so this can be useful for others
I remember now that in older navistack configurations there was a problem with min_vel_theta and max_vel_theta parameters, where the former must be negative. Type rosparam get /move_base/TrajectoryPlannerROS/min_vel_theta to ensure that's not your problem.
Originally posted by jorge with karma: 2284 on 2014-08-11
