When I compile my package with catkin_make I see this error:
prima@prima-UX32VD:~/catkin_ws$ catkin_make
Base path: /home/prima/catkin_ws
Source space: /home/prima/catkin_ws/src
Build space: /home/prima/catkin_ws/build
Devel space: /home/prima/catkin_ws/devel
Install space: /home/prima/catkin_ws/install
#### Running command: "make cmake_check_build_system" in "/home/prima/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/prima/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /home/prima/catkin_ws/devel;/opt/ros/hydro
-- This workspace overlays: /home/prima/catkin_ws/devel;/opt/ros/hydro
-- Using PYTHON_EXECUTABLE: /usr/bin/python
-- Python version: 2.7
-- Using Debian Python package layout
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/prima/catkin_ws/build/test_results
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- catkin 0.5.86
-- BUILD_SHARED_LIBS is on
-- ~~ traversing 1 packages in topological order:
-- ~~ - ompl_planner
-- +++ processing catkin package: 'ompl_planner'
-- ==> add_subdirectory(ompl_planner)
-- Using these message generators: gencpp;genlisp;genpy
CMake Error at /opt/ros/hydro/share/catkin/cmake/catkinConfig.cmake:72 (find_package):
Could not find a package configuration file provided by "ompl" with any of
the following names:
omplConfig.cmake
ompl-config.cmake
Add the installation prefix of "ompl" to CMAKE_PREFIX_PATH or set
"ompl_DIR" to a directory containing one of the above files. If "ompl"
provides a separate development package or SDK, be sure it has been
installed.
ompl_planner/CMakeLists.txt:7 (find_package)
make: *** [cmake_check_build_system] Errore 1
Invoking "make cmake_check_build_system" failed
but in my ompl package in /opt/ros/hydro/share/ompl/ there is the correct ompl-config.cmake file.
this is my CmakeLists.txt
project(ompl_planner)
roscpp
costmap_2d
geometry_msgs
nav_core
nav_msgs
pluginlib
tf
angles
ompl
catkin_package(
INCLUDE_DIRS include
LIBRARIES ompl_planner
CATKIN_DEPENDS roscpp nav_core pluginlib
include_directories(
include
${catkin_INCLUDE_DIRS}
add_library(ompl_planner
src/ompl_planner.cpp
install(TARGETS ompl_planner
LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
install(DIRECTORY include/ompl_planner/
DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
install(FILES
bgp_plugin.xml
DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
What can I do?
Originally posted by Stefano Primatesta on ROS Answers with karma: 402 on 2014-04-16
Comment by joq on 2014-04-17:
Most likely your workspace environment is wrong. Did you remember to source /opt/ros/hydro/setup.bash before first running catkin_make? Did you later source ~/catkin_ws/devel/setup.bash?
Comment by Stefano Primatesta on 2014-04-17:
I always do it. The problem is only with OMPL package, but not with other packages.
