Hello, I want to driver my Laserscanner under Android system (a smartphone or a tab). I am using Hokoyo Laserscanner UTM-30LX. Does anyone have experience?
How to supply the Laserscanner from smartphone or tab? Do I need an adapter to give the scanner appropriate Voltage?
Normally the USB in smartphone or tab has a mini USB. How can I use a Y cable to connect the Laserscanner and the smartphone or tab?
For your answer my heartfelt appreciation!
Originally posted by Yuliang Sun on ROS Answers with karma: 5 on 2014-02-03
