How is that distribution of ROS have?, This because when installing the lightweight simulator tutorial Understanding ROS nodes, I could not change my distro for alleged distribution is hydro, but it says there is no package or file I'm working with ubuntu 12.04 thanks for your help and attention given
Error message:
$ sudo apt-get install ros-<hydro>-ros-tutorials
Error bash: hydro: No such file or directory
Originally posted by felipe on ROS Answers with karma: 1 on 2014-01-30
Post score: -2
Comment by ahendrix on 2014-01-30:
Can you update your question with the exact command and error message that you're seeing?
Comment by felipe on 2014-01-30:
command
sudo apt-get install ros--ros-tutorials
Comment by gustavo.velascoh on 2014-01-30:
Did you install ROS following the instructions in http://wiki.ros.org/hydro/Installation/Ubuntu?
The command should be `$ sudo apt-get install ros-hydro-ros-tutorials´
gustavo.velascoh thank you very much for your great help and I could really solve my problem with the help of gustavo.velascoh you are all very friendly. good evening
