Are any commercially available compound vision sensors available? Not a simple 8 sensor system using photo-diodes but a genuine sensor that can provide a >32x32 compound matrix. Would some form of reduction in the granularity of a megapixel camera be a better option? The real purpose is to reduce processing time to a minimum, while extracting the maximum basic information.
$\begingroup$ Is there a problem with simply using a regular camera and resizing the image down to 32×32 pixels? $\endgroup$– IanCommented Mar 12, 2015 at 16:11
$\begingroup$ @Ian; I was looking for a compound vision sensor, but did ask if a reduction in a standard camera resolution would be better $\endgroup$– NeomadaCommented Mar 12, 2015 at 18:16
$\begingroup$ I'm asking if there's a specific reason why you wouldn't want to use the camera, since you seem to be having trouble finding the exact vision sensor you want. $\endgroup$– IanCommented Mar 13, 2015 at 21:13
$\begingroup$ @Ian; I would have liked to try a compound camera to enable some bio-emulation/understanding, but I will be using a camera (possibly limiting the number of pixels processed or merging blocks of pixels).Thanks $\endgroup$– NeomadaCommented Mar 14, 2015 at 13:36
Add a comment
1 Answer
The following people have used a compound eye for the development of their insect inspired rotor craft to demonstrate panoramic optical flow methods without the use of accelerometers.
The sensors are described here; Curvace
Paper here; Miniature curved artificial compound eyes
Video here; https://www.youtube.com/watch?feature=player_embedded&v=xKi5wSpslPE
With a detailed description of the fabrication here; Supporting Information
