Hello,
For our robot, slam gmapping have been configured. However, when we display our cost maps in rviz, we see a big gapping hole that isn't being mapped
screenshot http://www.muredblade.com/images/screenshot%20from%202013-05-22%2017_24_43.png
I know that there are quite a few parameters that can be set for gmapping.
Are any of these parameters responsible for this hole in our mapping?
Originally posted by mortonjt on ROS Answers with karma: 217 on 2013-05-22
3 Answers 3
For the SICK LMS lidar you can set the "use_rep_117_" global parameter to "false" to force it to report readings in legacy format instead of using Inf/NaN. It seems that the gmapping package rejects Inf/NaN values.
Use this information in combination with the maxRange and maxUrange suggestion that Ben has offered.
Originally posted by marcusrm with karma: 106 on 2013-05-23
Post score: 6
What is the maximum range of your laser scanner and what is the reading it gives if there is no object in range of the beam?
I think the problem is, that space where no echo is received by the scanner, is not marked as free. Have a look at the documentation of the ~maxRange parameter and try the proposed setting maxUrange < maximum range of the real sensor <= maxRange. But as far as i know, this depends on the scanner reporting readings of max range and not zero or NaN for beams where no echo is received.
If this does not solve your problem, maybe you could post a small bag file, so we can have a look for our own. :)
Originally posted by Ben_S with karma: 2510 on 2013-05-22
Post score: 4
Note that marking areas with no measurements received to be free can be risky in some cases, as you effectively don't know if things are out of range, or there's something in front of your LIDAR that the sensor just can't see (and that being the reason for getting no returns). The latter is a real possibility for some combinations of LIDARs and surface materials in the environment.
