Hello,
I am following the steps described in "Understanding ROS Topics" tutorial.
When I try to launch rqt_graph in the console I get this output:
user@user:~$ rosrun rqt_graph rqt_graph
Exception AttributeError: AttributeError("'_DummyThread' object has no attribute '_Thread__block'",) in <module 'threading' from '/usr/lib/python2.7/threading.pyc'> ignored
Which I believe is a normal output.
The rqt graph window opens but nothing is shown in it.
I don't know what could be wrong.
Thank you,
Originally posted by Pino on ROS Answers with karma: 88 on 2013-05-06
Comment by Pino on 2013-05-06:
Here is a screenshot of what I'm seeing: http://screencloud.net/v/qpXV
Comment by 130s on 2013-05-06:
This screenshot helps more to understand what's happening, and that looks odd. What happens when you run $ rqt
from command line and open "Plugins" --> "Graph" on it?
This works, now I can see the graph as shown here: http://screencloud.net/v/2bR7
But trying to run it directly using
still doesn't work
@Pino so if you open rqt_graph
via rqt
, not directly, do you see nodes & topics or whatever you wanted to see?
Comment by Pino on 2013-06-10:
Yes, opening via rqt solves the problem
