Hi everyone!
I'm trying to get the image from my Fire-i400 1394 camera. In order to do that, I am using the following comands:
$ rosrun camera1394 camera1394_node
$ ROS_NAMESPACE=camera rosrun image_proc image_proc
$ rosrun image_view image_view image:=camera/image_rect_color
and this should give me the images, with color. But I'm getting the following message:
Color topic '/camera/image_color' requested, but raw image data from topic '/camera/image_raw' is grayscale
then, the images come up, but they are on grayscale.
Does anybody know why it is happening? What am I doing wrong?
Thanks in advance!
Originally posted by Mendelson on ROS Answers with karma: 73 on 2013-04-17
Comment by joq on 2013-04-17:
What parameters did you set for the camera driver?
Comment by Mendelson on 2013-04-18:
Actually, I really don't know. I just plugged the camera, downloaded the packages, and, then, I calibrated it. How can I see these parameters? Thanks for your quick answer!
Comment by felix k on 2013-04-18:
See default params on that node's wiki page if you didn't set any.
You should take a look at the driver tutorials.
They explain how to run the driver, configure color parameters, and access the parameters using dynamic_reconfigure.
Originally posted by joq with karma: 25443 on 2013-04-18
Comment by Mendelson on 2013-04-23:
Thank you joq! Actually, I just had to use $ rosrun camera1394 camera1394_node _guid:=(my_cam_guid) _video_mode:=640x480_rgb8
