I installed Groovy and converted my package from rosbuild to catkin following a migration guide.
I wrote my CMakeLists.txt referenced Groovy's sources and CMakeLists.
I run catkin_make, failed about install DESTINATION.
Moirai@moirai:~/moirai-ws$ catkin_make
Base path: /home/Moirai/moirai-ws
Source space: /home/Moirai/moirai-ws/src
Build space: /home/Moirai/moirai-ws/build
Devel space: /home/Moirai/moirai-ws/devel
Install space: /home/Moirai/moirai-ws/install
#### Running command: "make cmake_check_build_system" in "/home/Moirai/moirai-ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/Moirai/moirai-ws/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/groovy
-- This workspace overlays: /opt/ros/groovy
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- catkin 0.5.63
-- BUILD_SHARED_LIBS is on
-- ~~ traversing packages in topological order:
-- ~~ - my_package
-- +++ processing catkin package: 'my_package'
-- ==> add_subdirectory(my_package)
CMake Error at my_package/CMakeLists.txt:18 (install):
install TARGETS given no RUNTIME DESTINATION for executable target
"my_package_node".
My CMakeLists.txt is
project(my_package)
find_package(catkin REQUIRED COMPONENTS sensor_msgs driver_base image_proc dynamic_reconfigure camera_calibration_parsers compressed_image_transport cv_bridge rospack)
find_package(OpenCV REQUIRED)
# include files
include_directories(${catkin_INCLUDE_DIRS})
include_directories(SYSTEM ${OpenCV_INCLUDE_DIRS})
include_directories(src/my_package_uvc)
include_directories(${CATKIN_DEVEL_PREFIX}/include/my_package)
# create my_package_node
add_executable(my_package_node src/my_package_node.cpp src/my_package_uvc/my_package_camera.cpp src/my_package_uvc/my_package_uvc.cpp)
target_link_libraries(my_package_node ${catkin_LIBRARIES} ${OpenCV_LIBRARIES})
install(TARGETS my_package_node
DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
# define the project
catkin_package(
INCLUDE_DIRS src/my_package_uvc
LIBRARIES ${PROJECT_NAME}
CATKIN-DEPENDS sensor_msgs driver_base image_proc dynamic_reconfigure camera_calibration_parsers compressed_image_transport cv_bridge
DEPENDS opencv
<br>
Where is ${CATKIN_PACKAGE_BIN_DESTINATION}?<br>
What am I doing wrong?
Originally posted by Moirai on ROS Answers with karma: 35 on 2013-02-04
Comment by Moirai on 2013-02-04:
catkin_make run successfully when I set my workspace directory as install destination.
DESTINATION ${CMAKE_INSTALL_PREFIX}/bin
I don' know how to configure "${CATKIN_PACKAGE_BIN_DESTINATION}.
