I've added these lines to foo/package.xml
<build_depend>mylib</build_depend>
<run_depend>mylib</run_depend>
and this to foo/CMakeLists.txt:
find_package(catkin REQUIRED COMPONENTS mylib)
and I added this rule to my local rosdep yaml file:
mylib:
arch: mylib-syspkg
but when I run rosdep keys foo, I get a blank line, and if I try rosdep install foo, I get "#All required rosdeps installed successfully". A rosdep resolve mylib call prints out "mylib-syspkg".
If I run catkin_make:
CMake Error at /opt/ros/groovy/share/catkin/cmake/catkinConfig.cmake:71 (find_package):
Could not find a package configuration file provided by "mylib" with any of
the following names:
mylibConfig.cmake
mylib-config.cmake
It looks as if nothing is associating the mylib dependency with the foo package. Is there some new command I should run to install a wet package's rosdep dependencies?
Originally posted by Ken on ROS Answers with karma: 438 on 2012-11-24
