I'm running ROS Noetic ros_comm on Raspian Buster, on a raspberry pi 4b. I've activated my catkin workspace, downloaded the navigation package, and extracted the package to catkin_ws/src
From /catkin_ws/, I ran
rosdep install --from-paths src --ignore-src -r -y
pi@raspberrypi:~/catkin_ws $ rosdep install --from-paths src --ignore-src -r -y
executing command [sudo -H apt-get install -y ros-noetic-angles]
Reading package lists... Done
Building dependency tree
E: Unable to locate package ros-noetic-angles
executing command [sudo -H apt-get install -y ros-noetic-tf2-geometry-msgs]
E: Unable to locate package ros-noetic-tf2-geometry-msgs
executing command [sudo -H apt-get install -y ros-noetic-dynamic-reconfigure]
E: Unable to locate package ros-noetic-dynamic-reconfigure
executing command [sudo -H apt-get install -y ros-noetic-geometry-msgs]
E: Unable to locate package ros-noetic-geometry-msgs
executing command [sudo -H apt-get install -y ros-noetic-nav-msgs]
E: Unable to locate package ros-noetic-nav-msgs
executing command [sudo -H apt-get install -y ros-noetic-tf2-ros]
E: Unable to locate package ros-noetic-tf2-ros
executing command [sudo -H apt-get install -y ros-noetic-tf2]
executing command [sudo -H apt-get install -y ros-noetic-sensor-msgs]
E: Unable to locate package ros-noetic-sensor-msgs
executing command [sudo -H apt-get install -y ros-noetic-visualization-msgs]
E: Unable to locate package ros-noetic-visualization-msgs
executing command [sudo -H apt-get install -y ros-noetic-tf2-sensor-msgs]
E: Unable to locate package ros-noetic-tf2-sensor-msgs
executing command [sudo -H apt-get install -y ros-noetic-laser-geometry]
E: Unable to locate package ros-noetic-laser-geometry
executing command [sudo -H apt-get install -y ros-noetic-map-msgs]
E: Unable to locate package ros-noetic-map-msgs
executing command [sudo -H apt-get install -y ros-noetic-diagnostic-updater]
E: Unable to locate package ros-noetic-diagnostic-updater
executing command [sudo -H apt-get install -y ros-noetic-tf2-msgs]
E: Unable to locate package ros-noetic-tf2-msgs
executing command [sudo -H apt-get install -y ros-noetic-move-base-msgs]
E: Unable to locate package ros-noetic-move-base-msgs
executing command [sudo -H apt-get install -y ros-noetic-actionlib]
E: Unable to locate package ros-noetic-actionlib
ERROR: the following rosdeps failed to install
apt: command [sudo -H apt-get install -y ros-noetic-angles] failed
apt: command [sudo -H apt-get install -y ros-noetic-tf2-geometry-msgs] failed
apt: command [sudo -H apt-get install -y ros-noetic-dynamic-reconfigure] failed
apt: command [sudo -H apt-get install -y ros-noetic-geometry-msgs] failed
apt: command [sudo -H apt-get install -y ros-noetic-nav-msgs] failed
apt: command [sudo -H apt-get install -y ros-noetic-tf2-ros] failed
apt: command [sudo -H apt-get install -y ros-noetic-tf2] failed
apt: command [sudo -H apt-get install -y ros-noetic-sensor-msgs] failed
apt: command [sudo -H apt-get install -y ros-noetic-visualization-msgs] failed
apt: command [sudo -H apt-get install -y ros-noetic-tf2-sensor-msgs] failed
apt: command [sudo -H apt-get install -y ros-noetic-laser-geometry] failed
apt: command [sudo -H apt-get install -y ros-noetic-map-msgs] failed
apt: command [sudo -H apt-get install -y ros-noetic-diagnostic-updater] failed
apt: command [sudo -H apt-get install -y ros-noetic-tf2-msgs] failed
apt: command [sudo -H apt-get install -y ros-noetic-move-base-msgs] failed
apt: command [sudo -H apt-get install -y ros-noetic-actionlib] failed
apt: Failed to detect successful installation of [ros-noetic-angles]
apt: Failed to detect successful installation of [ros-noetic-tf2-geometry-msgs]
apt: Failed to detect successful installation of [ros-noetic-dynamic-reconfigure]
apt: Failed to detect successful installation of [ros-noetic-geometry-msgs]
apt: Failed to detect successful installation of [ros-noetic-nav-msgs]
apt: Failed to detect successful installation of [ros-noetic-tf2-ros]
apt: Failed to detect successful installation of [ros-noetic-tf2]
apt: Failed to detect successful installation of [ros-noetic-sensor-msgs]
apt: Failed to detect successful installation of [ros-noetic-visualization-msgs]
apt: Failed to detect successful installation of [ros-noetic-tf2-sensor-msgs]
apt: Failed to detect successful installation of [ros-noetic-laser-geometry]
apt: Failed to detect successful installation of [ros-noetic-map-msgs]
apt: Failed to detect successful installation of [ros-noetic-diagnostic-updater]
apt: Failed to detect successful installation of [ros-noetic-tf2-msgs]
apt: Failed to detect successful installation of [ros-noetic-move-base-msgs]
apt: Failed to detect successful installation of [ros-noetic-actionlib]
Why won't rosdep successfully install my dependencies? Is this possible to fix?
Thank you
Originally posted by g-builds on ROS Answers with karma: 3 on 2020-12-26
Comment by jayess on 2020-12-28:
@g-builds if @tfoote's answer answered your question, then please click on the check mark (✓) next to the answer instead of closing the question
