I am trying to build a servo-controlled water valve. Max pressure 150 psi , valve size 1/2".
Can anyone recommend a suitable 1/4-turn valve, either ceramic, ball valve, or anything else that is easy to turn, even under pressure? It must require very little torque to turn, so a standard servo can rotate it with a small lever attached.
7
    $\begingroup$ What's your application? I'm not sure something like an RC servo is the right solution here. Are you familiar with solenoid valves? $\endgroup$
    – Guy Sirton
    Aug 31, 2014 at 23:41
  • $\begingroup$ Application is controlling water flow, so a solenoid (on/off only) is not suitable. I need to be able to partially open/close the valve to allow various flow rates. Thanks! $\endgroup$ Sep 1, 2014 at 11:10
  • $\begingroup$ There are commercial units available, very expensive. I am trying to build my own for a low cost application. $\endgroup$ Sep 1, 2014 at 11:12
  • $\begingroup$ It looks like what i want is called a 'proportional valve' as per electronics.stackexchange.com/questions/60370/… $\endgroup$ Sep 1, 2014 at 11:21
    $\begingroup$ If you have feedback you may be able to modulate (e.g. PWM) an on-off valve to get the flow you need... $\endgroup$
    – Guy Sirton
    Sep 1, 2014 at 18:45
It is pretty common to take a simple and cheap solenoid valve and use a PWM at the input
TI has a pretty nice driver (DRV102) which uses a analog input and provides enough power to switch the most valves. I don't even need a MCU, just a variable resistor is enought Then just take a cheap valve and the job is done
  • $\begingroup$ Very interesting. Does the liquid exit the line in visible pulses? $\endgroup$ Sep 4, 2014 at 10:48
    $\begingroup$ The used PWM is about 24kHz You cannot see any pulses the piston in the valve is just kept in a middle position proportinal to the duty cycle of the pwm $\endgroup$
    – TobiasK
    Sep 4, 2014 at 11:30
  • $\begingroup$ This is exactly the info i was looking for. I did not know solenoid valves could use PWM to partially open. I assumed the valve would pulse open and closed, causing choppy water output. Thank you! $\endgroup$ Sep 5, 2014 at 1:50
