Question 1.. Can I just use wheel odometry data and imu data and get effective kalman updated data using robot_pose_ekf package?Is there any package which is more handy which I overlooked?
Question 2.. The output of /robot_pose_ekf/odom_combined is same as the /pose published by wheel odometry. Do I have to make any changes?
Question3..Message update rate is around 5 sec and can I decrease it ?
I tried changing the freq parameter in robot_pose_ekf.launch from 30 hz to 120 hz but the update comes around once in 5 sec.
Sometimes the output does not start immediately.
nutan@nutan-laptop:~$ rostopic hz /robot_pose_ekf/odom_combined
subscribed to [/robot_pose_ekf/odom_combined]
average rate: 0.018
min: 55.560s max: 55.560s std dev: 0.00000s window: 2
no new messages
no new messages
no new messages
no new messages
average rate: 0.033
min: 5.054s max: 55.560s std dev: 25.25297s window: 3
no new messages
no new messages
no new messages
no new messages
average rate: 0.046
min: 5.053s max: 55.560s std dev: 23.80890s window: 4
no new messages
no new messages
no new messages
no new messages
average rate: 0.057
min: 5.053s max: 55.560s std dev: 21.86982s window: 5
no new messages
no new messages
no new messages
no new messages
average rate: 0.066
min: 5.053s max: 55.560s std dev: 20.20241s window: 6
no new messages
no new messages
no new messages
no new messages
no new messages
no new messages
no new messages
no new messages
no new messages
no new messages
no new messages
Originally posted by sai on ROS Answers with karma: 1935 on 2012-09-23
Finally after three days, found the answer...
First the error was
"Could not transform the imu messages from /base_imu to /base_footprint"
This was found from the rxconsole output.
TF tree was connected.
It was solved by changing the (/base_imu)frame id of IMU to /base_footprint
Thats it...:)
Originally posted by sai with karma: 1935 on 2012-10-01
Comment by jarvisschultz on 2012-10-01:
Glad you solved the problem. Would you mind marking the answer as accepted?
Comment by sai on 2012-10-03:
did that
Comment by autonomy on 2013-01-22:
This helped me figure out why EKF's update rate was incorrect. Just like in your case, the EKF node was complaining about the IMU messages not having base_footprint IDs. After specifying "base_footprint" for the "frame_id" param for the IMU node, the EKF node's rate increased to 5Hz - our GPS rate
Comment by sai on 2013-01-28:
its nice that you posted back saying that this was useful
