hi, i am trying to use the explore stack in gazebo, but i get the following warnings:
[ WARN] [1342514709.419049768, 713.848000000]: Costmap2DROS transform timeout. Current time: 713.8480, global_pose stamp: 713.5130, tolerance: 0.3000
[ WARN] [1342514708.892588284, 711.502000000]: Map update loop missed its desired rate of 5.0000Hz... the loop actually took 0.2230 seconds
i dont't find a doku about the explore stack just the examples...can anyone help me ?
Originally posted by pkohout on ROS Answers with karma: 336 on 2012-07-16
Comment by salma on 2013-04-21:
please can you tell me how you used explore stack in gazebo ?
i tried it ,it begin to draw the map, but it didn't move on rviz without teleop
you have to change tranform tolerance, set it to something like 0.5 and you have to decrease update_frequency in global costmap params and local costmap params. it is stated to have them same in navigation tuning wiki
Originally posted by cagatay with karma: 1850 on 2012-07-17
Comment by pkohout on 2012-07-17:
ok thanks, the warning are now gone. but i have still a problem, i dont publish anything on the slam_entropy topic, which pkg publishes there something ? do you have some advise ?
Comment by cagatay on 2012-07-17:
gmapping publsihes entropy, maybe slam_entropy can be remapped type of it
remapping works, the explore nodes subscribes it...but still nothing happens.... did i have to call a service or so that the explore node starts exploring or so ??
Comment by cagatay on 2012-07-19:
yes it can subscribe it but is remapped topic being published ?
Comment by pkohout on 2012-07-19:
nope remapped topic does not publish anything ://
Comment by pkohout on 2012-07-23:
now it all get published and subscribed, but i get the following info after starting exploration:Done exploring with 0 goals left that could not be reached. There are 0 goals on our blacklist, and 0 of the frontier goals are too close to them to pursue. The rest had global planning fail to them.
exploration complete .... do you have any ideas ?
