Hi all,
I am facing a strange problem. I am using ROS move_base and SBPL for motion-primitive-based path planning. I have generated some motion primitives for SBPL and everything works fine using my laptop (Intel i5, Ubuntu 14.04). The robot plans the path and moves fine along the path.
Now I am using the very same modules (and configs) on my Odroid U3 (ARM quadcore) and it cannot find a solution. Top shows that the core is at 100%. Here is the output from move_base
[ INFO] [1412691428.999248673]: Using plugin "obstacle_layer"
[ INFO] [1412691429.127272381]: Subscribed to Topics:
[ INFO] [1412691429.172789423]: Using plugin "inflation_layer"
[ INFO] [1412691429.443358089]: Name is SBPLLatticePlanner
[ INFO] [1412691430.931921673]: Planning with ARA*
[ INFO] [1412691430.932365757]: [sbpl_lattice_planner] Initialized successfully
[ INFO] [1412691430.989290632]: Using plugin "obstacle_layer"
[ INFO] [1412691431.241103424]: Subscribed to Topics:
[ INFO] [1412691431.286346674]: Using plugin "inflation_layer"
[ INFO] [1412691431.688199674]: Created local_planner base_local_planner/TrajectoryPlannerROS
[ INFO] [1412691431.732307049]: Sim period is set to 0.10
[ INFO] [1412691432.897083008]: odom received!
[ INFO] [1412691492.209781994]: [sbpl_lattice_planner] getting start point (3.48925,-0.84064) goal point (2.00517,-1.3133) [ INFO] [1412691502.490063749]: Solution not found
[ WARN] [1412691502.492333249]: Map update loop missed its desired rate of 2.0000Hz... the loop actually took 10.0025 seconds
[ INFO] [1412691502.492543791]: [sbpl_lattice_planner] getting start point (3.48925,-0.84064) goal point (2.00517,-1.3133)
[ INFO] [1412691512.771037004]: Solution not found
I am using the following repos of the modules:
ROS indigo
sbpl_lattice_planner: https://github.com/meyerj/sbpl_lattice_planner.git
sbpl: https://github.com/sbpl/sbpl.git
Any ideas? I actually have no Idea where to start looking.
Cheers,
Markus
Originally posted by Markus Eich on ROS Answers with karma: 202 on 2014-10-07
The problem is the ambiguity of the char datatype. On x86 gcc it defaults to signed, on ARM to unsigned. This results in negative values getting flipped.
See here: http://www.arm.linux.org.uk/docs/faqs/signedchar.php
and here: https://github.com/sbpl/sbpl/blob/master/src/include/sbpl/discrete_space_information/environment_navxythetalat.h#L61
one solution is to simply compile with the -fsigned-char switch, forcing all chars to be signed
## Compiler flags
if(CMAKE_COMPILER_IS_GNUCXX)
    ## signed char is default on x86 gcc, not on arm however.
    set(CMAKE_CXX_FLAGS "-fsigned-char")
endif()
Originally posted by philipp.schmutz with karma: 56 on 2015-02-16
Post score: 4
Comment by philipp.schmutz on 2015-02-16:
https://github.com/sbpl/sbpl/pull/27
In general, this error means that SBPL timed out before it could find a path connecting that start and goal points.
There are a few things you can try (in order from easiest to hardest):
  • Make sure SBPL and sbpl_lattice_planner are compiled in release mode ( catkin_make -DCMAKE_BUILD_TYPE=Release )
  • Increase the global planner timeout
  • Decrease the global costmap resolution
  • Decrease the number of SBPL primitives
Originally posted by ahendrix with karma: 47576 on 2014-10-08
Comment by Markus Eich on 2014-10-09:
This does not seem to help much.
  • compiling with release did not improve the issue
  • Set Global planner time out to 10 seconds. still no result
  • I have set the resolution to 10cm. Still no solution
Decreasing the number of primitives is where I am currently stuck.
I am using the genprim_unicylce method. When I set the numberofangles=8, I can generate the primitives but the planner simply crashes.
Comment by ahendrix on 2014-10-09:
You may want to try choosing a goal point that's closer or further away from the robot.
