For example, I want to analysis roscpp call graph.
Which tools I can use? How?
It will very great if it has graphical interface.
Thank you~
Originally posted by sam on ROS Answers with karma: 2570 on 2012-04-05
Comment by PKG on 2012-04-05:
Can you use doxygen or codeviz?
Comment by sam on 2012-04-05:
Thank you. I found that I can use doxywizard to generate each function's call graph,but where is the whole picture call graph? Another question is codeviz should patch compiler,so it seems very hard to work on ROS. How to do it?
I also found that doxywizard just generate partial call graph. Because I found that the function it generate call graph failed (roscpp init.cpp init() ). Is there any tool can generate complete call graph? Thank you~
