i am learning ros through the steps given in the tutroials the problem i am facing is that when i type $ roscore " ... logging to ~/.ros/log/9cf88ce4-b14d-11df-8a75-00251148e8cf/roslaunch-bvo-13039.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://bvo:33919/ ros_comm version 1.4.7
SUMMARY
PARAMETERS
- /rosversion
- /rosdistro
NODES
auto-starting new master process[master]: started with pid [13054] ROS_MASTER_URI=http://bvo:11311/
setting /run_id to 9cf88ce4-b14d-11df-8a75-00251148e8cf process[rosout-1]: started with pid [13067] started core service [/rosout]" the answer is similar like this but when i type $ rosnode list on other terminal it gives me an error that no command found what is the problem???
Originally posted by danish on ROS Answers with karma: 11 on 2012-02-19
