I'm trying to find machines that publish a certain type of message. Therefore I'm inspecting the list of rosnodes rosnode.rosnode_listnodes() and would like to get the IP address of the corresponding machines running a specific node.
There is a method rosnode.lookup_uri(...), but I have no idea how to use it. I also looked into the rospy, rosgraph, names and network modules - so far without success. Among other information,rosnode.rosnode_info(node_name) prints the URI. But it might be a rather expensive method and, unfortunately, it returns None.
Originally posted by Falko on ROS Answers with karma: 268 on 2016-11-04
>>> import rosgraph
>>> master = rosgraph.Master('/mynode')
>>> master.lookupNode("node_name')
This worked for me, but not sure if it's safe to deal with ros master directly this way.
Originally posted by huanxiner with karma: 271 on 2016-11-04
Comment by gvdhoorn on 2016-11-05:
Alternatively, you could use the Master API directly.
Comment by Falko on 2016-11-07:
Great, thanks! Apparently, you can even get the master via rosgraph.Master(''). It's definitely the answer I was looking for. :)
