I'm using laser_scan_matcher node to be working with my node. The problem I'm now having is that I've my /world defined somewhere in my code. In laser_scan_matcher, I need to set the value for publish_tf as true, or else, it'll complaint. I can set publish_tf as true, but then, the output and the robot movement is really weird or wrong. Whenever I try to set the publish_tf as false, I receive the following serious warning:
[ WARN] [1329318619.876324732]: Warning: Frame id /world does not exist! Frames(3):Frame /laser exists with parent /base_link.
Frame /base_link exists with parent NO_PARENT.
Without the laser_scan_matcher node, my own node works out-of-the-box. I've also seen the code of laser_scan_matcher, they also define "world" frame. Do they clash? Any idea how to resolve this?
EDIT
In my broadcaster node:
static tf::TransformBroadcaster tfb;
tf::Transform xform;
xform.setOrigin(tf::Vector3(previous_poseLD2_.pose.position.x-starting_position_x, previous_poseLD2_.pose.position.y-starting_position_y, previous_poseLD2_.pose.position.z));
xform.setRotation(tf::Quaternion(previous_poseLD2_.pose.orientation.x, previous_poseLD2_.pose.orientation.y, previous_poseLD2_.pose.orientation.z, previous_poseLD2_.pose.orientation.w));
tfb.sendTransform(tf::StampedTransform(xform, ros::Time::now(), "/world", "/base_link"));
In another node:
tfListener_.waitForTransform("/world", "/laser", ros::Time::now(), ros::Duration(20.0));
On top of that, I have a static transform publisher from base_link to laser.
BTW, I'm specifically interested to use the pose information(x, y and delta) to be integrated with my node.
Here is the laser_scan_matcher xml:
 <node pkg="laser_scan_matcher" type="laser_scan_matcher_node" name="laser_scan_matcher_node" output="screen">
   <param name="use_alpha_beta" value="true"/>
   <param name="max_iterations" value="10"/>
   <param name="publish_tf" value="false"/>
 </node>
Originally posted by alfa_80 on ROS Answers with karma: 1053 on 2012-02-15
Comment by DimitriProsser on 2012-02-15:
How often does this warning appear? Is it only one time? Or is it continuous?
Comment by alfa_80 on 2012-02-15:
It's continuous but not frequent.
Let's examine the frames laser_scan_matcher works with:
  • the sensor frame - typically this is "/laser"
  • the base frame - typically this is /base_link
  • the world frame - typically this is world (or sometimes odom)
The tf from the base frame to the sensor frame is assumed to be static. It should be published by a static TF publisher
The tf from the world frame to the base frame will be published by laser_scan_matcher, and will represent the moving pose of the robot in the world.
If you publish a tf from /world to /base_link in your code (and the publish_tf param is true), that will result in a conflict with the scan matcher, since base_link now has two parents.
I might be able to provide more help if you describe your usage scenario and what your node is doing.
Originally posted by Ivan Dryanovski with karma: 4954 on 2012-02-15
I've updated as above. Thanks anyway for getting involved.
I could see as well, it's kinda conflict. Previously, I got a 3D .point cloud, but after integrating your node, I got 2D cloud, and the robot was strangely moving.
I think for the publish_tf param, I can set to false, because I don't need the one from your node I think. Anyway, I'm opened to any fix.
Comment by Ivan Dryanovski on 2012-02-15:
Where is xform coming from (how is it computed)? Also, the can matcher is meant to work with laser data (2d). What 3d cloud do you have?
Kindly refer to EDIT part, because I've just added some more info.
@Ivan Dryanovski: Should I set a fixed_frame param in the laser_scan_matcher's xml? At the moment, I didn't set it.
previous_poseLD2_.pose.position.x is computed by taking the difference of the current and previous value of y-value of pose2D and accordingly for x-component. I integrate this difference value over time.
Do I have some other frame conflict like, I defined static transform publisher(laser->base) differently from yours in terms of parameter values and so on?
Is there any reason to take the difference and then integrate? This would just give you the pose that the laser publishes. Are you trying to remove a constant initial offset?
"This would just give you the pose that the laser publishes.." yes, I use this pose to be integrated with my initial pose. Any idea to resolve this frame conflict?
Comment by Ivan Dryanovski on 2012-02-16:
Have the scan_matcher publish a pose, but not a tf (by setting the params). Then (in your node) subscribe to the pose message, do your calculations, and publish a tf. This way, only one world->base_link tf is published, and there are no conflicts.
Comment by alfa_80 on 2012-02-16:
I did the step you suggested, but, it still ends up with this error message "[ WARN] [1329401873.937791965]: Warning: Frame id /world does not exist! Frames (3): Frame /laser exists with parent /base_link. Frame /base_link exists with parent NO_PARENT."
I think I have a problem with setting the /world frame id. I'll resolve this one first.
laser_scan_matcher does not define the /world frame. By convention, the /world frame is never defined. laser_scan_matcher requires that a transform from /base_link exist. If you do not publish this transform, laser_scan_matcher can for you. This would represent the sensor's travel with respect to the world.
The frame /world is simply the default. If you would like to measure the robot's travel with respect to the /map frame, you only need to change the fixed_frame parameter. If you do not want to publish tf from laser_scan_matcher, simply change the fixed_frame to some static frame you use in your code (/map for example).
Originally posted by DimitriProsser with karma: 11163 on 2012-02-15
I defined already the transform of base_link with respect to world like this: " tfb.sendTransform(tf::StampedTransform(xform, ros::Time::now(), "/world", "/base_link"));"
And from /laser wrt /world like this:"tfListener_.waitForTransform("/world", "/laser", ros::Time::now(), ros::Duration(20.0));" Am I missing anything else?
@alfa_80: Those tf's will likely result in a conflict - see my answer
