So I am trying to map a model(urdf) to my hector slam project which seems to have base_frame. I don't have any base_link?
rosrun tf tf_echo /map /base_link
CFailure at 1485981006.541937303 Exception thrown:"base_link" passed to lookupTransform argument source_frame does not exist. The current list of frames is: Frame laser exists with parent base_frame. Frame base_frame exists with parent map. Frame scanmatcher_frame exists with parent map.
If I change my URDF from base_link to base_frame, I have less errors in RVIZ but the wheels are not connected to the robot?
Originally posted by burf2000 on ROS Answers with karma: 202 on 2017-02-01
Comment by spmaniato on 2017-02-01:
base_frame is a ROS parameter. base_link is a common value of the base_frame parameter.
There is no difference, both of them are the parameters used too mention the base frame of the tf tree. In order to approach your scenario, change the base frame name in URDF to base_link else run the tf node as below
$rosrun tf tf_echo /map /base_frame
Originally posted by Kishore Kumar with karma: 173 on 2017-02-01
Comment by burf2000 on 2017-02-01:
If I update my URDF file to base_frame, my wheels are not attached
