I want to use an unscented kalman filter (UKF) in ROS to do state estimation. I can't find any ROS packages that implement an UKF so I've been looking around at filtering libraries for C++ that I could use within ROS. Does anyone have any recommendations? I've found the following libraries but many are poorly documented or inactive. Any suggestions?
UKF support:
No UKF support:
Mobile Robot Programming Toolkit (The main page lists UKFs but the code doesn't appear to implement them)
Orocos Bayesian Filtering Library
Originally posted by Andrew Chambers on ROS Answers with karma: 96 on 2011-12-21
Post score: 5
Comment by Martin Peris on 2011-12-21:
Hi Andrew! OpenCV implements Kalman Filter, Extended Kalman Filter (EKF) and is fully integrated with ROS. But I am afraid it doesn't implement UKF (as far as I know).
