Is there a turtlebot model in stage ? Has anyone made it ?
Originally posted by Arkapravo on ROS Answers with karma: 1108 on 2011-11-25
3 Answers 3
Hi, I've been using Stage for over a year... I think it won't be a turtlebot model for stage, the main reason is the turtlebot's Kinect wich has no equivalent sensor in Stage.
In Stage you can find a Roomba+LaserScanner model to progam and play with very didactic, and good to play with navigation, tracking and other stuff. Stage Tutorials
If you look for a Robot+[RGB+d camera] simulation, like turtlebot, this should be done in Gazebo wich is really capable of such tasks.
I apologize I cannot suggest a specific turtlebot model in Gazebo, my knowledge is not deep enough.I just try to give a little help, good luck! :)
Originally posted by marcobecerrap with karma: 107 on 2011-11-25
Comment by Arkapravo on 2011-11-25:
@marcobecerrap : Thank you, however that tutorial you referred to - it is written by me ! :-)
There currently is a full TurtleBot simulator in gazebo that uses the URDF model provided in the turtlebot stack. For more information check out the turtlebot_simulator wiki page: http://www.ros.org/wiki/turtlebot_simulator
Comment by Arkapravo on 2011-11-26:
@mwise_wg : thanks, marcobecerrap has given me the answer I was looking for - the reason for no stage model for turtlebot
Answering my own question
Clearly the best simulator for the turtlebot is the turtlebot simulator in gazebo as pointed out by Melonee, however a very simple Stage implementation in ROS Electric can be found here - http://pr.willowgarage.com/wiki/CS225B/Simulator
Originally posted by Arkapravo with karma: 1108 on 2012-10-07
