Can I change the stage/stageros robot models properties in runtime wihtout restarting the stage simulator?
Originally posted by Pablo Iñigo Blasco on ROS Answers with karma: 2982 on 2011-12-17
Comment by Pablo Iñigo Blasco on 2011-12-20:
The attatched patch in my own answer is a solution for the problem itsef. As Perco suggested I requested this enhacement. I only focused on laser config so this patch can be improved. Almost any aspect of Stage can be reconfigured in runtime using this template - Bridge ros-service C++Stage API
Comment by Arkapravo on 2011-12-20:
@Pablo Iñigo Blasco : I am using Stage (as Player/Stage and also as ROS/stageros) for about 2 years now, I am very apprehensive of any solution to your problem. I follow your question most keenly.
Comment by Pablo Iñigo Blasco on 2011-12-17:
I've refactored the entry to clarify what is the question and what is the answer.
Currently there is no support for this feature. Maybe somebdoy need it. Here you also can find the answer about how to solve the problem.
Comment by joq on 2011-12-17:
Is this a question?
This is not currently supported.
However here you can find a partial solution.
Here I attached a patch over the stage package which provides a service to change elemental attributes of lasers beams of the robot models. This service can be also a template for further runtime configuration changes.
Example:
import roslib
roslib.load_manifest('stage')
import rospy
import stage.msg
import stage.srv
stage_model_config_srv=rospy.ServiceProxy('/stageros/set_models_configurations',stage.srv.SetModelConfig)
model_config=stage.msg.ModelConfig()
model_config.laser_fov=-1.0
model_config.laser_range_max=-1
model_config.laser_range_min=-1
model_config.laser_resolution=-1
model_config.laser_samples=8
stage_model_config_srv(models_configurations=[model_config])
It was useful for some test bencharks in my research and maybe will be useful for someone else.
But the below diff text is a good resume of the changes made. However the attached patch (rename from it to .diff) C:\fakepath\stage_configuration_service.diff.jpg should be used. It is a bit more verbose (a lot of indentation eclipse-ros format changes)
This patch have been applied over:
URL: https://code.ros.org/svn/ros-pkg/stacks/stage/trunk
Repository Root: https://code.ros.org/svn/ros-pkg
Repository UUID: eb33c2ac-9c88-4c90-87e0-44a10359b0c3
Revision: 38364
Diff text:
Index: msg/ModelConfig.msg
--- msg/ModelConfig.msg (revision 0)
+++ msg/ModelConfig.msg (revision 0)
@@ -0,0 +1,8 @@
+#geometry_msgs/Pose2D laser_pose
+#to maintiain its current value set each config property to -1
+int32 laser_samples
+int32 laser_resolution
+float64 laser_fov
+int32 laser_range_max
+int32 laser_range_min
Index: src/stageros.cpp
--- src/stageros.cpp    (revision 38364)
+++ src/stageros.cpp    (working copy)
@@ -47,6 +47,7 @@
 #include
 #include "tf/transform_broadcaster.h"
+#include "stage/SetModelConfig.h"
 #define USAGE "stageros "
 #define ODOM "odom"
@@ -79,6 +80,9 @@
     std::vector cmdvel_subs_;
     ros::Publisher clock_pub_;
+    ros::ServiceServer models_configurations_service_;
+    bool model_config_callback(stage::SetModelConfig::Request& request, stage::SetModelConfig::Response& response);
     // A helper function that is executed for each stage model.  We use it
     // to search for models of interest.
     static void ghfunc(Stg::Model* mod, StageNode* node);
@@ -213,9 +217,47 @@
   this->laserMsgs = new sensor_msgs::LaserScan[numRobots];
   this->odomMsgs = new nav_msgs::Odometry[numRobots];
   this->groundTruthMsgs = new nav_msgs::Odometry[numRobots];
+  this->models_configurations_service_ = localn.advertiseService("set_models_configurations", &StageNode::model_config_callback, this);
+bool StageNode::model_config_callback(stage::SetModelConfig::Request& request, stage::SetModelConfig::Response& response)
+  boost::mutex::scoped_lock lock(msg_lock);
+  if(request.models_configurations.size()>lasermodels.size())
+    ROS_ERROR("Service stage model config: configurations.count > simulator_models.count");
+    return false;
+  for(unsigned int i=0;ilasermodels[i]->GetConfig();
+    if(current_msg_config.laser_samples!=-1)
+      laser_config.sample_count=current_msg_config.laser_samples; ///SetConfig(laser_config);
+  return true;
 // Subscribe to models of interest.  Currently, we find and subscribe
 // to the first 'laser' model and the first 'position' model.  Returns
 // 0 on success (both models subscribed), -1 otherwise.
Index: srv/SetModelConfig.srv
--- srv/SetModelConfig.srv  (revision 0)
+++ srv/SetModelConfig.srv  (revision 0)
@@ -0,0 +1,2 @@
+ModelConfig[] models_configurations
\ No newline at end of file
Index: CMakeLists.txt
--- CMakeLists.txt  (revision 38364)
+++ CMakeLists.txt  (working copy)
@@ -22,6 +22,9 @@
 include_directories(${STAGE_INCLUDE_DIRS} ${PROJECT_SOURCE_DIR}/include/Stage-3.2)
 link_directories(${STAGE_LIBRARY_DIRS} ${PROJECT_SOURCE_DIR}/lib)
+rosbuild_genmsg()
+rosbuild_gensrv()
 rosbuild_add_executable(bin/stageros src/stageros.cpp)
 rosbuild_link_boost(bin/stageros thread)
Originally posted by Pablo Iñigo Blasco with karma: 2982 on 2011-12-17
Done. https://code.ros.org/trac/ros-pkg/ticket/5307
Comment by Eric Perko on 2011-12-17:
I suggest you open an enhancement ticket against the stage package and attach the patch to that. That way, this patch won't get lost and may make it into a future release of the stage package. Please update your answer to include that trac link once you create the ticket.
