Hi,
I'm trying to build a system utilizing gmapping and laser_scan_matcher ( laser_scan_matcher to improve the odometry of my robot). I've already made the system work utilizing the bag that came with laser_scan_matcher. Using
Fixed_Frame: odom Base_Frame: base_link
But when I try to use the same setup in conjunction with stage, a concurrent tf transform problem arises.
I kind of understand the problem the laser_scan_matcher publishes the odom to base_footprint and stageros does also.
But I'm lost how to solve it i tried to modify stageros to not publish the transform but laser scan matcher needs the inicial transform.
Thanks in advance
Originally posted by fmarques on ROS Answers with karma: 92 on 2011-10-29
Comment by Brian Gerkey on 2011-10-31:
Unfortunately, stageros uses hardcoded frame names. But gmapping's frame names are configurable via parameters. Can you change the frame names used by laser_scan_matcher? If so, you should be able to configure the system to run all three components without conflicts.
That would create a problem, yes. Only one node should be publishing that transform. I'm not familiar with how stageros works, but if it's publishing the odom->base_link transform, you need to disable that.
That shouldn't be the case. The only tf that laser_scan_matcher requires is base_link -> laser. That can be published by a static tf publisher, or by stage.
laser_scan_matcher is intended as a replacement for odometry, for robots without odom sensors. If your robot already has an odometry sensor, then you can provide its measurements as an optional input to laser_scan_matcher, and the scan matcher will refine them. The odom sensor's measurements would need to be published on a topic (not as a tf). I would get the base case working first though (no odometry) and then attempt this case.
Could you describe your use case in a little more detail? You are working with simulated data? What sensors does the robot have?
Also, attaching the console output would be helpful, so we can see what warnings/errors you are getting.
Ivan
Originally posted by Ivan Dryanovski with karma: 4954 on 2011-10-31
Comment by fmarques on 2011-10-31:
So I did change the stageros cpp to not publish the odom-> base_fooprint( base_link) and that solved the problem everything running smooth now. It works fine using the odom topic or not. So thank you very much.
