Hi, I've tried the pi_tracker package. I have no errors running skeleton.launch and tracker.launch. However, when I rosrun rviz, I met the following errors
[ERROR] [1316763642.701371303]: TF_NO_FRAME_ID: Ignoring transform with child_frame_id "/right_shoulder" from authority "/skeleton_tracker" because frame_id not set [ERROR] [1316763642.701422097]: TF_NO_FRAME_ID: Ignoring transform with child_frame_id "/right_elbow" from authority "/skeleton_tracker" because frame_id not set [ERROR] [1316763642.701475147]: TF_NO_FRAME_ID: Ignoring transform with child_frame_id "/right_hand" from authority "/skeleton_tracker" because frame_id not set
Originally posted by ychua on ROS Answers with karma: 71 on 2011-09-22
Comment by ychua on 2011-09-22:
In rviz, in TF display. I got status: warning "/openni_camera: No transform from [/openni_camera] to frame[/world] /openni_depth_frame: No transform from [/openni_depth_frame to frame[/world]" etc....
The robot model in the rviz has no errors. I've also changed the 'skel_to_joint_map' parameter in the tracker_params.yaml, to correspond with the joint names with my robot urdf model. I also changed the line in the 'self.cmd_joints.position[self.cmd_joints.name.index('myRobot_jointName')] = right_shoulder_lift_angle' in the tracker_joint_controller.py to my robot urdf's joint name.
Is there anywhere else I need to change in the code? Thanks a lot!
You need to change the fixed frame and target frame to something connected in rviz. See the user guide
Originally posted by tfoote with karma: 58457 on 2011-11-27
check your urdf: my case was
<joint
    name="right_forward_steering_joint"
    type="continuous">
    <origin
      xyz="-0.71499 0.65792 0.2505"
      rpy="1.5708 0 0" />
    <parent
      link="base_link" />
    <child
      link="right_forward_steering" />
    <axis
      xyz="0 0 0" />
</joint>
the xyz axis was (0 0 0), i solved it by adding 1 in the axis of rotation so it will be
<axis xyz="0 1 0" />
Originally posted by youssef desouky with karma: 11 on 2020-07-14
