Dear All,
I was just wondering if anyone successfully managed to use wifi_comm.
As far as I know I followed the instructions to the letter, successfully managed to install olsrd and also make the wifi_comm.
wifi_discovery_node and wifi_com_example are running fine.
I have 2 laptops connected Ad-Hoc, each running the software.
I can see their IP addresses on olsrd and also in the topic list. Ping works from one machine to another and also SSH, so presumably the network connection is fine.
In my case I would see
/wifi_hello_world
/wifi_hello_world_192_168_20_100
/wifi_hello_world_192_168_20_101
/wifi_neighbours_list
amongst others.
Hello World is being generated in each machine and can be seen when using
rostopic echo /wifi_hello_world
Also, machine with IP 192_168_20_100 can see data streaming in /wifi_hello_world_192_168_20_100, again using rostopic echo /wifi_hello_192_168_20_100
Somehow though data (Hello World) is not being transferred from one machine to the other and machine with IP 192_168_20_101 keeps waiting for data to be sent in.
Looks like the problem is somewhat related to foreign_relay (as same happens when I just use that)
Any help is greatly appreciated. Thanks in advance
Originally posted by roboviz on ROS Answers with karma: 26 on 2011-07-13
